Hi folks,
I learned this year that my z's rear struts have visibly different angles where the strut tube is inserted into the bearing housing.  This explains a lot, the car has always had a funky driver-side rear toe issue, and it's off enough that with urethane bushings and the new adjustable LCA's, the driver-side LCA had to be torqued to get the main bolt thru.  Not good, we know, but the car is just a roller for now so it shouldn't affect anything.
Anyway, there are a few threads on this, it's a fairly common issue, but is there a way to fix it aside from hoping to find a replacement strut?  Can the tube be separated from its housing and adjusted to proper angle?
Thanks guys!
Just find another strut housing. It probably was damaged in a wreck or something. You spend more time and money trying to repair that one then just finding a good one.
