Posted December 30, 201410 yr comment_461002 Hello everyone, working on the dash harness and I am looking to buy the signal terminal connector as mine is all burned up. I'm going to try Mike at ZZX but wanted to have other sources just in case. Thx! Link to comment https://www.classiczcars.com/forums/topic/50687-where-to-get-single-terminal-connector-for-alternator-circuit/ Share on other sites More sharing options...
December 30, 201410 yr comment_461006 http://www.vintageconnections.com/ShoppingCart.htm Link to comment https://www.classiczcars.com/forums/topic/50687-where-to-get-single-terminal-connector-for-alternator-circuit/#findComment-461006 Share on other sites More sharing options...
December 31, 201410 yr Author comment_461016 first place I checked. I'm assuming your referring to MP1L? It's close but I don't have the top lock just a notch on the housing. Link to comment https://www.classiczcars.com/forums/topic/50687-where-to-get-single-terminal-connector-for-alternator-circuit/#findComment-461016 Share on other sites More sharing options...
January 5, 201510 yr Author comment_461318 Any other suggestions? Link to comment https://www.classiczcars.com/forums/topic/50687-where-to-get-single-terminal-connector-for-alternator-circuit/#findComment-461318 Share on other sites More sharing options...
January 5, 201510 yr comment_461319 you can get the complete connector (both halves) from vintage connections and just replace it. easier than trying to match... Link to comment https://www.classiczcars.com/forums/topic/50687-where-to-get-single-terminal-connector-for-alternator-circuit/#findComment-461319 Share on other sites More sharing options...
January 5, 201510 yr Author comment_461334 you can get the complete connector (both halves) from vintage connections and just replace it. easier than trying to match...Good point, for some reason I thought it went into the alternator. I did find the original design though on Eastern Beaver.http://easternbeaver.com/Main/Elec__Products/Connectors/312_Connectors/312_connectors.html Link to comment https://www.classiczcars.com/forums/topic/50687-where-to-get-single-terminal-connector-for-alternator-circuit/#findComment-461334 Share on other sites More sharing options...
