Finally installed Z's onthe brain head light upgrade.
If it wasn't for a PO's butchering of the headlight hookup on the right side it would have been painless.
Great upgrade. I had it sitting ready a while but naturally I waited till I also had to take the headlight switch off due to
overheating and cleanup and repair it also.http://www.kamikazeracing.org/dl/ZTe...mbo_switch.pdf
Great link if you are a little handy.
Middle pic is the connector some one used instead of proper one.
Buddy of mine in the Ontario z car club gave me proper connectors and a little time with a meter test light and wiring diagram
made it happen. With a Bosch H4 headlight upgrade that was already installed I will have to use my lowbeams :D
Still am going to cleanup the harness in front of the rad. I have all winter :angry:
post-20199-0-44509800-1420424199_thumb.j
post-20199-0-68351400-1420424260_thumb.j
post-20199-0-22514500-1420424347_thumb.j
second round of rings, bearings, seals, gaskets, oil pump, and timing set
repeat the valve job
refresh the su's
log a few break-in miles
and order a new brake booster
wheeee!
Guest
This topic is now closed to further replies.
