[2015] What Did You Do To/with Your Z Today?
zed2
Completed changing all my fluids today with the transmission gear oil .  The transmission now has Redline MT90.
Now that I have changed it, I know I'll soon run across a late ZX 5 speed, do the swap, and get to change the gear oil again.
 Not sure what diff you are running now but if you make the change for the ZX 5 speed be sure to research a 3.9 diff - if you have the $ review a STi LSD......it might put a grin on your face
Just clean the float valve......if it's dirty, gas will discharge through your air cleaner and onto the floor, hopefully without disastrous results!
I'm going to get a couple new gaskets for the float bowls before I open them up and then, hopefully, clean the crud and corruption around the valve to fix the problem. The last thing I need is an EXTERNAL combustion engine.
Dennis
They don't have Grose jets anymore, or at least I didn't get them a couple of months ago with my rebuild kit.  Seems like I googled them and they're not made anymore.  The ones now look like OE Nissan but with a skinnier pin, they look like valve stems without the hat.
More like these, no ball bearing.
I went to my local Nissan dealer's parts department today to see if I could order a couple float bowl gaskets and the young guy behind the counter says they are NLA.  Anyone gotten them from a dealer lately?  (part# 16064-22010)
I see that they're available from a few places on line, including Courtesy Nissan, but i hate to pay almost $10 shipping on a $1.25 gasket if I can get them locally.  I've had better luck with the older parts guy at the dealership in tracking down Datsun parts.
Dennis
I was supposed to clear the snow off the roof but after hearing the news about Mr. K's passing, the only thing to do was to get back to work on the Z.
A dual EGT (#2 & #5 header pipes), a fuel pressure, tranny temp and two O2 sensors gauges. All to better know when to hit the kill switch before the whole engine is toast.
post-6539-0-74434900-1424749457_thumb.jp
Dennis
Same here, older is better!  Usually if Courtesy can get something my local parts guy can get it.  Try this number, 16455-H2310
Here's some valve numbers I found too, 16101-10400 & 16101-25610
Thanks!  I'll give it another try at the local dealer.
Dennis
Just got back from the local Nissan dealer.  Today, an older parts specialist was behind the counter.  I gave him the part number for the float bowl gasket that was NLA yesterday.  He looked it up and asked how many hundred I wanted.  I ordered three at $1.70 each and they'll be here Thursday morning.
Lesson learned:  Always ask for the "old guy" behind the counter when ordering vintage Z parts at the Nissan dealership.
Dennis
Guest
This topic is now closed to further replies.
  • Who's Online   2 Members, 0 Anonymous, 682 Guests (See full list)
