gundee Posted June 15, 2015 Share #217 Posted June 15, 2015 Finished restoring the Mikuni manifold. Should be back on the car tomorrow. Then the carbs back on soon to drive by this weekend. Link to comment Share on other sites More sharing options...
oranngetang Posted June 15, 2015 Share #218 Posted June 15, 2015 That manifold looks great!Adjusted valves and installed oil cooler today, fresh K&N and Brad Penn with the lean needles. Link to comment Share on other sites More sharing options...
mgood Posted June 16, 2015 Share #219 Posted June 16, 2015 Changes the front breakes on my 76. Took about 30 minutes should be good for at least 20 years. The last set lasted at least 25.Got them from RockAuto they were Wagner PD161 for $20 shipped. Link to comment Share on other sites More sharing options...
psdenno Posted June 19, 2015 Share #220 Posted June 19, 2015 The saga of my "new" ZTherapy carbs continues. Got the ZTherapy carbs within the promised timeframe and swapped them out for my original 44 year old set. ( Pictures here: http://www.classiczcars.com/gallery/album/517-ztherapy-carbs/ ). My mechanic installed the carbs and noted gas spewing from the float bowl hose on the front carb. I called ZTherapy and they have a replacement hose in the mail to me - good folks to deal with. I'm looking forward to getting the Z back on the road next week. Then the fun begins as I get the body ready for paint and new window gaskets. Too much fun! I still need the small piece of rear hatch glass stainless trim ( top corner piece, passenger side ) if anyone has a spare sitting in a box in the garage.Dennis Link to comment Share on other sites More sharing options...
siteunseen Posted June 19, 2015 Share #221 Posted June 19, 2015 I agree, Ztherapy is a great model for small business owners. They've got it right.Can't wait to see the new paint. What code number is yours? Will you paint the spoilers with the radar paint? SMILEY Link to comment Share on other sites More sharing options...
psdenno Posted June 19, 2015 Share #222 Posted June 19, 2015 Carbs aren't my only issue at the moment. I have a leak around the transmission port where the speedometer drive gear is located. The two required seals pictured in the following link are still available from Nissan ( http://www.classiczcars.com/gallery/album/524-speedometer-gear-seals/ ) as part #s 32709-14600 and 32710-14600 and also from MSA. MSA is about $1 cheaper for the pair plus shipping and a week's wait as they travel through the postal system. My local Nissan dealer had then to me in two days. Dennis Link to comment Share on other sites More sharing options...
psdenno Posted June 19, 2015 Share #223 Posted June 19, 2015 I agree, Ztherapy is a great model for small business owners. They've got it right.Can't wait to see the new paint. What code number is yours? Will you paint the spoilers with the radar paint? SMILEY Good memory on you about the aircraft radome paint on my spoiler. The days are far behind when I could stroll into the aircraft fabrication shop on base and ask for my broken spoiler to be fixed and painted. This time will just be plain old off the shelf rattle can black paint after the Z is painted. It's been at least 115º here most days this week, so hoping for a little cooler weather when I start prepping the body for paint. Nothing happens quickly.Dennis Link to comment Share on other sites More sharing options...
charliekwin Posted June 22, 2015 Share #224 Posted June 22, 2015 Finally got the last coat of paint on all the suspension parts this evening. On schedule to reassemble everything next weekend. Link to comment Share on other sites More sharing options...
gundee Posted June 22, 2015 Share #225 Posted June 22, 2015 Got the Pertronix conversion wired in and fired it up.They are correct. It did change the timing and had to reset.Had to re-adjust carbs too.Really sounds good. Road test later after I finish a coupleother minor things on it. Link to comment Share on other sites More sharing options...
siteunseen Posted June 23, 2015 Share #226 Posted June 23, 2015 Finally got the last coat of paint on all the suspension parts this evening. On schedule to reassemble everything next weekend.Did you have to thin that chassis paint much? Seems pretty thin already and from I read on their website they recommend 5% acetone. I usually do 30% to 50% on most other paints. I use a gravity HVLP gun to spray a bunch of light coats, maybe that's why I have to thin it down so much? Thanks for any tips. Link to comment Share on other sites More sharing options...
charliekwin Posted June 23, 2015 Share #227 Posted June 23, 2015 Did you have to thin that chassis paint much? Seems pretty thin already and from I read on their website they recommend 5% acetone. I usually do 30% to 50% on most other paints. I use a gravity HVLP gun to spray a bunch of light coats, maybe that's why I have to thin it down so much? Thanks for any tips. I shot it straight from the can. To date, this paint is the only stuff I've ever sprayed, so I have no basis of comparison, but it seems to go on fine without thinning. I'm using the Harbor Freight HVLP gun and the tip it comes with (1.4mm, I think). I'm being patient and letting everything bake in the sun until late in the week before I try reassembling everything, but so far -- fingers crossed! -- I think I had better results with it than I did on the fuel tank. Just guessing here, but I think letting the primer cure for 4 days might have helped. 1 Link to comment Share on other sites More sharing options...
Pop's Z Posted June 23, 2015 Share #228 Posted June 23, 2015 (edited) Yesterday went out for a bit of a cruise. Got a ticket from a Sheriff's deputy on a motorcycle with forward look radar for 13 over. He knocked it down to 5 over and 1 point. I was totally guilty. I've owned the Zed for 10 years. I have done some serious hooning about in it. I paid the $98 fine...that averages out to $9.80/ year. Cheap for all the fun I've had. Ironically the last speeding ticket I got was in 1975 in my '73 Zed for 30 over. When I think about all the times I could have been busted I just smile. Cheers, Mike Edited June 24, 2015 by Pop's Z 2 Link to comment Share on other sites More sharing options...
