Posted January 21, 201510 yr comment_462270 Hello everyone. I have some nuts, bolts, clamps basically hardware that are in pretty good shape. I would like to soak them overnight in a liquid cleaning solution such as simple green or Castrol's super clean. Does anyone have a recommendation on what to use that won't remove the original plating? Thanks! Link to comment https://www.classiczcars.com/forums/topic/50824-what-cleaner-to-use-on-hardware-without-removing-original-plating/ Share on other sites More sharing options...
January 21, 201510 yr comment_462272 Grease - Purple PowerRust - Evapo Rust Link to comment https://www.classiczcars.com/forums/topic/50824-what-cleaner-to-use-on-hardware-without-removing-original-plating/#findComment-462272 Share on other sites More sharing options...
January 22, 201510 yr comment_462274 concentrated simple green is stronger than most people give it credit, and its easier to deal with that noxious chemicals Link to comment https://www.classiczcars.com/forums/topic/50824-what-cleaner-to-use-on-hardware-without-removing-original-plating/#findComment-462274 Share on other sites More sharing options...
January 22, 201510 yr comment_462289 I have had good results with Murphy's Oil Soap and hot water soak then old toothbrushes. Link to comment https://www.classiczcars.com/forums/topic/50824-what-cleaner-to-use-on-hardware-without-removing-original-plating/#findComment-462289 Share on other sites More sharing options...
January 22, 201510 yr Author comment_462294 thanks for the replies! I am assuming Simple Green will remove paint off of hardware if soaked long enough? Link to comment https://www.classiczcars.com/forums/topic/50824-what-cleaner-to-use-on-hardware-without-removing-original-plating/#findComment-462294 Share on other sites More sharing options...
January 22, 201510 yr comment_462295 I've never seen Simple green remove paint before but it will etch polished aluminium if left on too long. Link to comment https://www.classiczcars.com/forums/topic/50824-what-cleaner-to-use-on-hardware-without-removing-original-plating/#findComment-462295 Share on other sites More sharing options...
January 22, 201510 yr comment_462303 There should be no paint on your hardware. All of it should be yellow zinc. Soak it in Mineral Spirits or Carb cleaner. Link to comment https://www.classiczcars.com/forums/topic/50824-what-cleaner-to-use-on-hardware-without-removing-original-plating/#findComment-462303 Share on other sites More sharing options...
January 22, 201510 yr Author comment_462318 I've never seen Simple green remove paint before but it will etch polished aluminium if left on too long. Ok thanks! There should be no paint on your hardware. All of it should be yellow zinc. Soak it in Mineral Spirits or Carb cleaner.Thanks for the tip. I did notice some hardware being silver zinc? For example the flat head Philips screw door latch on the b pillar Link to comment https://www.classiczcars.com/forums/topic/50824-what-cleaner-to-use-on-hardware-without-removing-original-plating/#findComment-462318 Share on other sites More sharing options...
