Posted January 24, 201510 yr comment_462363 I picked up a cheap L16 original atsugi water pump and have started researching to see if it will fit my L28. I know about the pulley offset problem and was wondering if anyone has swapped water pump pulleys from another datsun to correct the offset problem. The size of the impellers looks comparable to the L28 pump despite the fact that its for a smaller engine. Since the source of LD28 water pumps has long since dried up, I ran across a page where someone compared the impeller size on the Z20-22-24 and it looked like the LD28 pump with the larger impellers and the post said it bolted on the L4 with no modification. But there again the problem of L4 and L6 pulley offset differences. I really don't want to use shims. I'de like to find a pulley solution. Before too long, the source of NEW atsugi pumps for the L6's will also dry up and it would be nice to find another source of pumps. I personally don't want to rely on the cheap stamped impeller autozone ones. While in my search for water pump swaps, I found out that you can use an L28 water pump on an L4. Just use the water pump pulley from a SOHC KA in the hardbody. Link to comment https://www.classiczcars.com/forums/topic/50835-l4-water-pump-on-an-l6/ Share on other sites More sharing options...
January 24, 201510 yr Author comment_462365 For comparison, the LD28 is the new pump on the left and the Z22 pump is the right picture. Is it my imagination that the z22 impellers look bigger than the stock L28 pump thats to the left of the LD28 pump? They certainlay look taller. But does taller move more water? There is more surface area but is it the length of the impeller that makes the difference? The bigger impellers do work. There was a guy down in australia that hooked up a fuel pressure gauge to measure before and after water pressure. Before 28 psi and after installing a larger water pump 35 psi. Link to comment https://www.classiczcars.com/forums/topic/50835-l4-water-pump-on-an-l6/#findComment-462365 Share on other sites More sharing options...
January 24, 201510 yr comment_462375 Are you trying to find an LD28 analog or a stock gasoline-powered L28 analog? You have the L4 pump, don't you have an L28 pump? I have an L28 pump to take measurements from. Not really clear what you're asking. Link to comment https://www.classiczcars.com/forums/topic/50835-l4-water-pump-on-an-l6/#findComment-462375 Share on other sites More sharing options...
January 24, 201510 yr Author comment_462397 On 1/24/2015 at 3:19 AM, Zed Head said: Are you trying to find an LD28 analog or a stock gasoline-powered L28 analog? You have the L4 pump, don't you have an L28 pump? I have an L28 pump to take measurements from. Not really clear what you're asking.I picked up a cheap L16 original atsugi water pump and have started researching to see if it will fit my L28. I know about the pulley offset problem and was wondering if anyone has swapped water pump pulleys from another datsun to correct the offset problem. Link to comment https://www.classiczcars.com/forums/topic/50835-l4-water-pump-on-an-l6/#findComment-462397 Share on other sites More sharing options...
January 24, 201510 yr comment_462399 That narrows it down. The LD28 pump is typically used by people that want more coolant flow. The cast impeller pumps are commonly available though for the typical L28. The LD thing confused me. Still not totally clear though, to me. I think that you're saying that the height of the water pumps are different, putting the pulley mounting flange closer/farther from the front of the engine. You didn't say specifically but it looks like you're assuming that the L$ pump impeller will fit the L28 timing cover and bolt up correctly, and the only issue is the pulley mounting flange offset. Anyway, looks interesting. If you supplied some measurements people could check their pulleys. Short answer, for me, is no I have not tried this. I do have some L28 pumps that I could measure though. As I said. Link to comment https://www.classiczcars.com/forums/topic/50835-l4-water-pump-on-an-l6/#findComment-462399 Share on other sites More sharing options...
January 24, 201510 yr comment_462402 According to Advanced Auto the '83 Maxima Diesel pump has the same part number for a '72 240Z. It's a remanufactured Atsugi if you look at the pictures. http://shop.advanceautoparts.com/p/driveworks-water-pump-remanufactured-57-1016/20420100-P?vehicleIdFromReq=-1&isAllVehicle=false&vehicleIdSearch=18855&searchTerm=57-1016&showTitle=# Link to comment https://www.classiczcars.com/forums/topic/50835-l4-water-pump-on-an-l6/#findComment-462402 Share on other sites More sharing options...
January 24, 201510 yr comment_462404 Exact fit for my 77 also. Link to comment https://www.classiczcars.com/forums/topic/50835-l4-water-pump-on-an-l6/#findComment-462404 Share on other sites More sharing options...
January 24, 201510 yr Author comment_462405 On 1/24/2015 at 10:28 PM, Zed Head said: That narrows it down. The LD28 pump is typically used by people that want more coolant flow. The cast impeller pumps are commonly available though for the typical L28. The LD thing confused me. Still not totally clear though, to me. I think that you're saying that the height of the water pumps are different, putting the pulley mounting flange closer/farther from the front of the engine. You didn't say specifically but it looks like you're assuming that the L$ pump impeller will fit the L28 timing cover and bolt up correctly, and the only issue is the pulley mounting flange offset. Anyway, looks interesting. If you supplied some measurements people could check their pulleys. Short answer, for me, is no I have not tried this. I do have some L28 pumps that I could measure though. As I said. Do you have any water pump pulleys that have 4 holes and are from other datsun engines. i.e. A12 , E15, KA? Link to comment https://www.classiczcars.com/forums/topic/50835-l4-water-pump-on-an-l6/#findComment-462405 Share on other sites More sharing options...
January 24, 201510 yr comment_462406 There's a whole big thread on Hybridz about the LD pumps. Apparently, the original LD pumps pushed more coolant so people wanted them for their performance engines. But they don't make them anymore so the parts places are selling the gasoline pumps as LD pumps, or getting them mixed up. There are subtle differences in the pump body and blades. Some people ordered LD pumps and got gas pumps, some got LD pumps. And, for a while, the cast impeller pumps were hard to find,m apparently, only the stamped impellers were available. And they weren't very good. That's all I know. I'm always looking for easy part swaps though, so if a cheaper L4 pump will do the job with just a different pulley, that would be neat. The main reason I posted... Link to comment https://www.classiczcars.com/forums/topic/50835-l4-water-pump-on-an-l6/#findComment-462406 Share on other sites More sharing options...
January 24, 201510 yr comment_462407 On 1/24/2015 at 11:38 PM, hr369 said: Do you have any water pump pulleys that have 4 holes and are from other datsun engines. i.e. A12 , E15, KA? I only have 280Z and 280ZX pulleys. I'll be keeping my eyes open in the wrecking yards in the future though. Link to comment https://www.classiczcars.com/forums/topic/50835-l4-water-pump-on-an-l6/#findComment-462407 Share on other sites More sharing options...
January 24, 201510 yr Author comment_462408 On 1/24/2015 at 11:18 PM, siteunseen said: According to Advanced Auto the '83 Maxima Diesel pump has the same part number for a '72 240Z. It's a remanufactured Atsugi if you look at the pictures. http://shop.advanceautoparts.com/p/driveworks-water-pump-remanufactured-57-1016/20420100-P?vehicleIdFromReq=-1&isAllVehicle=false&vehicleIdSearch=18855&searchTerm=57-1016&showTitle=#Yes they will fit but its not the same pump. Its the impeller size thats different. Link to comment https://www.classiczcars.com/forums/topic/50835-l4-water-pump-on-an-l6/#findComment-462408 Share on other sites More sharing options...
January 24, 201510 yr Author comment_462411 On 1/24/2015 at 11:39 PM, Zed Head said: There's a whole big thread on Hybridz about the LD pumps. Apparently, the original LD pumps pushed more coolant so people wanted them for their performance engines. But they don't make them anymore so the parts places are selling the gasoline pumps as LD pumps, or getting them mixed up. There are subtle differences in the pump body and blades. Some people ordered LD pumps and got gas pumps, some got LD pumps. And, for a while, the cast impeller pumps were hard to find,m apparently, only the stamped impellers were available. And they weren't very good. That's all I know. I'm always looking for easy part swaps though, so if a cheaper L4 pump will do the job with just a different pulley, that would be neat. The main reason I posted... Exactly, cheaper and better quality and possibly higher water pump pressure (z22 pump) using nissan parts with an easy pulley swap. Its still in the mail. I will measure the pulley offset when it arrives. Link to comment https://www.classiczcars.com/forums/topic/50835-l4-water-pump-on-an-l6/#findComment-462411 Share on other sites More sharing options...
