Posted January 28, 201510 yr comment_462568 Hi friends,my clutch disk needs a replacement. Centerforce doesn't sell the disk separated. Why should I buy a total new kit when I only need a new disk? What is the special of the centerforce 2 disk and has anyone of you an idea what I can use instead and where to get it.Thanks for your help!Rolf Link to comment https://www.classiczcars.com/forums/topic/50857-centerforce-2-clutch-disk/ Share on other sites More sharing options...
January 28, 201510 yr comment_462586 Buy a stock clutch disc from Nissan. Link to comment https://www.classiczcars.com/forums/topic/50857-centerforce-2-clutch-disk/#findComment-462586 Share on other sites More sharing options...
January 28, 201510 yr comment_462596 I thought it was good practice to replace it all if you are going to replace any of it (?) Link to comment https://www.classiczcars.com/forums/topic/50857-centerforce-2-clutch-disk/#findComment-462596 Share on other sites More sharing options...
January 28, 201510 yr comment_462607 I think it depends on how far you let things go before.  Some people recommend just scuffing up the pressure plate and flywheel with sandpaper if there are no grooves or heat-check spots and the surfaces are still flat (checked with a good straight edge).  Monroe describes it in his How To Rebuild book. AS for where to get them, RockAuto has a good selection, the auto parts stores still stock them, and Nissan dealers may still carry them also.  After sanding the two metal surfaces, clean them well with brake cleaner.  You'll need to know the size of the pressure plate and flywheel.  But the disc itself fits the transmission shaft, so that's what matters, aside from friction surface size.  I've sanded and cleaned a flywheel surface with no issues, using a pressure plate and disc kit. 30100-Y6800 http://www.courtesyparts.com/clutch-dis-p-329045.html  (225 mm) Link to comment https://www.classiczcars.com/forums/topic/50857-centerforce-2-clutch-disk/#findComment-462607 Share on other sites More sharing options...
January 28, 201510 yr Author comment_462608 Hi trcb, in principle you are right but my presssure plate and flywheel look good and are not old. I had to take my engine out as I had to replace the front cover.So I thought it might be a good idea to replace the clutch disk and some more parts.John, does the stock clutch disk for the 240 Z work with the centerforce 2? Motorsports said "No" but as far as I know you by your comments I believe in your experiance with tuned Zs.Thanks for your support Link to comment https://www.classiczcars.com/forums/topic/50857-centerforce-2-clutch-disk/#findComment-462608 Share on other sites More sharing options...
January 28, 201510 yr Author comment_462609 Thanks Zed head Link to comment https://www.classiczcars.com/forums/topic/50857-centerforce-2-clutch-disk/#findComment-462609 Share on other sites More sharing options...
January 29, 201510 yr comment_462634 From your first post I didn't know you have the CF pressure plate. Â In my experience the Centerforce dual friction stuff sucks. Â I would just get a stock pressure plate and clutch from Nissan. Link to comment https://www.classiczcars.com/forums/topic/50857-centerforce-2-clutch-disk/#findComment-462634 Share on other sites More sharing options...
January 29, 201510 yr Author comment_462642 Ok, thank you JohnRolf Link to comment https://www.classiczcars.com/forums/topic/50857-centerforce-2-clutch-disk/#findComment-462642 Share on other sites More sharing options...
January 29, 201510 yr Author comment_462643 Thanks John! Is the stock clutch still ok for 210 hp? That's why I bought the centerforce 2 some time ago and stored the stock one for my other stock 240. Link to comment https://www.classiczcars.com/forums/topic/50857-centerforce-2-clutch-disk/#findComment-462643 Share on other sites More sharing options...
January 30, 201510 yr comment_462677 It depends on how you drive the car. Â I ran a stock clutch and pressure plate with about 190 hp and it lasted for at least 25,000 miles of racing and autocross. Â A friend had a stock clutch behind 150 hp and it lasted 7,000 miles. Link to comment https://www.classiczcars.com/forums/topic/50857-centerforce-2-clutch-disk/#findComment-462677 Share on other sites More sharing options...
January 30, 201510 yr Author comment_462690 Thank you for this informativ and encouriging reply. I know now what to do. Link to comment https://www.classiczcars.com/forums/topic/50857-centerforce-2-clutch-disk/#findComment-462690 Share on other sites More sharing options...
