March 20, 20159 yr comment_466077 Let us know how it works. Would be an easy way to fix this kind of damage.C Link to comment https://www.classiczcars.com/forums/topic/50861-triple-weber-mixture-screw-disaster/?&page=2#findComment-466077 Share on other sites More sharing options...
March 22, 20159 yr Author comment_466157 SUCCESS!!! :-DJust wanted to let everyone know that I got the carbs back on today and the car started and ran beautifully! The mixture screws were right where we put them during the last real tune and before I over-tightened them.Final tip here, to make sure it never happens again, I found it next to impossible to find the "bottom" with the spring, washer, etc., so with the carbs off the car so I could watch from the inside, I removed the spring, rubber o-ring, and washer, and found the bottom. I marked the screw (ground a bit off that side) and the carb, so now I know where not to go past in the future. Worked really well--especially for a novice like me. Hope this is all helpful to someone else!P.S. Blue, I've been reading your posts on tuning...maybe I should take back "beautiful" and just say it ran as well as it ever did...you really have some impressive information posted...I'll look it over more carefully now that I have the car running again! Wahooo! Link to comment https://www.classiczcars.com/forums/topic/50861-triple-weber-mixture-screw-disaster/?&page=2#findComment-466157 Share on other sites More sharing options...
March 22, 20159 yr comment_466160 so glad it worked out - always cool to see something repaired with skill and ingenuity vs. the "just throw new parts at it" approach.you are a hero. now get it tuned to blue's level and post a video! Link to comment https://www.classiczcars.com/forums/topic/50861-triple-weber-mixture-screw-disaster/?&page=2#findComment-466160 Share on other sites More sharing options...
March 22, 20159 yr Author comment_466171 Heh heh. I'm not sure "hero" is the right noun...I was the one who messed them up in the first place! ;-D I'll do some more reading on Blue's posts...too bad he's so far away from MN! Link to comment https://www.classiczcars.com/forums/topic/50861-triple-weber-mixture-screw-disaster/?&page=2#findComment-466171 Share on other sites More sharing options...
March 24, 20159 yr comment_466302 Great! Repair looks good and it sounds like you're back to reasonable numbers for where to put the screws. Glad you found someone who had the welding skills to do the repair! Link to comment https://www.classiczcars.com/forums/topic/50861-triple-weber-mixture-screw-disaster/?&page=2#findComment-466302 Share on other sites More sharing options...
