1976 280Z Restoration Project
wheee!
Cant wait to see some tear down pics! Have you looked under the battery tray, doglegs, frame rails, and spare tire well? These are usually hot spots for rust.
Anyone know the correct length for the driveshaft to be cut between the second generation 5 spd and the r200 diff? I have a 280zx driveshaft with the correct splines, but I realize it may be too long and need to be shortened to fit my 280Z
Sent from Canadia
I believe the stock 280Z shaft will work. I may be wrong though.
The rust looks minimal from above and the battery tray is pretty good. I know the car has been repainted several times so I am hoping that most of the rust has been treated/repaired at that time. I have not been under the car yet. I am a little scared to see the shape of things under there...!
There IS a ton of undercoating on the car though. The last guy COVERED the bottom of the car with the stuff and for good measure sprayed the whole engine bay and underhood with it too... FML
I have been trying to be patient. I really want to finish the garge before I start the tear down so I can do it properly. I want to have a clean space to start and proper shelving etc. I want to do a proper layout too (space is 24x24 dbl garge) and possibly include a paintbooth area that can be quickly setup and torn down. A friend of mine has hooked me up with a couiple industrial in-line ventilation systems and he will be building the downdraft ducting for it too. Go big or go home!
My next big question is: should I buy a dual media blaster kit that can blast soda as well as crushed glass etc or should I just mechanically strip everything on the body? The mess of media blasting the body (less sheet metal, possibly soda blasting those parts) is what's holding me back. Local companies start at about $1500 to blast a stripped body around here... I will be buying a proper sand blasting cabinet for the heavy duty stripping of old parts.
I will post a full journals worth of pics as I go. May even install a go-pro in the garage too!
My info comes from here:
http://www.zcarz.us/TechnicalInformationPageTransmission.htm
DRIVESHAFT
(the tricky part in a 1st generation Z)
The Nissan T5 came with a special driveshaft to fit the 280ZX. It is stouter and fatter than other Z driveshafts, has a different spline count on the front end, and a square flange on the rear. In other words, the only driveshaft that will fit the T5 is the one that came with it. A 240/260/280 driveshaft cannot be modified to fit.
LENGTH: The T5 driveshaft is almost the same length as regular Zcar driveshaft, but the T5 transmission is a few inches longer. This means if you use a Nissan T5 trans/driveshaft in a first generation Z the driveshaft will be too long by about 2-3 inches. The solution is to have a custom driveshaft made, or have the stock one shortened. Most driveshaft shops can fabricate one if you tell them what you want, about $300. A cheaper solution for us budget ZCAR people is to have the stock one shortened and rewelded, about $100. This gets tricky because driveshafts should be shortened only at the ends for balance reasons. And for some reason Nissan T5 driveshafts neck down to smaller diameters right at the flanges. This means that after cutting, the yoke and flange ends are too small to weld up to the center tube.
I don't have the Borg Warner 5 spd, but that might be my mistake in reading that article.... I have the "B" version (later) 5 spd. It is not clear as to whether or not my 280Z or 280ZX driveshaft will bolt up directly to the stock R200 rear end without modification.... ???
Can anyone clear this up for me?
The bolt patterns and centering/locating ring sizes are the same for the 240Z - 280ZX NA cars (non-FS5R90A transmission).  Sometimes there is confusion about square versus round flanges but Nissan made both with the same pattern and size for the 280Z's.  I have one of each.  I also have differentials from 1976 up to 1983.  I have a 1983 diff in my 1976 car with 1980 NA transmission right now, with a 1978 propeller shaft.The shape of the flange does NOT indicate the pattern and locating ring size.  300ZX's are different size but came with a square flange also.
On the length: the propeller shaft lengths are shown in the PD (Propeller shaft and differential) chapters of the FSM's.  I'd use those numbers over anybody's well-intentioned efforts with a tape measure.  But for the cost of shortening a 280ZX propeller shaft you could probably find a 280Z shaft somewhere.  Maybe even two or three. They last a long time.
Edited by Zed Head
I have an '81 5 speed and my stock shaft bolted right up so you should be good.  :)
That is great news!
So you are saying the 280Z shaft I have (stock) should bolt up fine to the 3.90 R200 (round flange) and the late 5 Spd transmission? If so, you have made my day... I was not looking forward to shortening a 280ZX driveshaft!
  • Who's Online   0 Members, 0 Anonymous, 635 Guests (See full list)
