July 9, 20159 yr comment_473494 I don't think the bumper shocks and mounts are designed for that vector. A lot of weight hanging from a pretty long lever arm. Might work, but if it doesn't you'll be very disappointed. Edited July 9, 20159 yr by Zed Head Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=8#findComment-473494 Share on other sites More sharing options...
July 9, 20159 yr Author comment_473498 Been done before... This is a local buddies 280 on the same rotisserie. https://vimeo.com/133069906Sent from my iPizzle ringy dingy device.... Edited July 9, 20159 yr by wheee! Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=8#findComment-473498 Share on other sites More sharing options...
July 9, 20159 yr comment_473505 I would have used the shock mounting holes instead of the shocks, but a stripped chassis is not very heavy Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=8#findComment-473505 Share on other sites More sharing options...
July 10, 20159 yr Author comment_473515 I agree. The stripped chassis is easily supported by the shocks. I did not make the rotisserie and it worked perfectly fine on the car in the video. Couple that with the fact the shocks will be discarded once the build progresses in favour of the replica 240 bumpers. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=8#findComment-473515 Share on other sites More sharing options...
July 14, 20159 yr Author comment_473941 Pulled the taillights and some interior panels from the hatch area. I am totally blown away that there is no rust and almost pristine spare tire area.... Pics to come. I am thinking that this area will need little more than a wipe down for restoration... I will probably respray the original colour in places, but I was expecting a lot worse... Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=8#findComment-473941 Share on other sites More sharing options...
July 15, 20159 yr Author comment_473965 Took the spare intake in to work for some rough hacking and smoothing. Getting it ready for the eventual pallnet fuel rail. Sent from my iPizzle ringy dingy device.... Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=8#findComment-473965 Share on other sites More sharing options...
July 16, 20159 yr Author comment_474032 Little more progress. Sent from my iPizzle ringy dingy device.... Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=8#findComment-474032 Share on other sites More sharing options...
July 21, 20159 yr Author comment_474238 Small steps. Took apart the front grill area. Most of the screws were seized. Had to drill them out. Removed the hood, muffler and small engine parts. Now just have to detach the driveshaft... Looks kinda cramped in there!Sent from my iPizzle ringy dingy device.... Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=8#findComment-474238 Share on other sites More sharing options...
July 21, 20159 yr comment_474243 it is - you have to rotate the propeller shaft to get the u-joint to open up for a wrench. pita, but doable. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=8#findComment-474243 Share on other sites More sharing options...
July 21, 20159 yr comment_474247 Mark, try using some visegrips on the screw heads if the slots strip out. Sounds like you're having a good time! Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=8#findComment-474247 Share on other sites More sharing options...
July 21, 20159 yr Author comment_474248 On 7/21/2015 at 12:23 PM, takayuki said: Mark, try using some visegrips on the screw heads if the slots strip out. Sounds like you're having a good time!I tried that on the ones that had visible head room. Most were inset so it was drill them or nothing. Drilling worked fine and was not too bad, just time consuming. I assumed there would be a lot of stripped and rusted bolts. The PO had also replaced a lot of factory bolts with wood screws etc....! Scary. Sent from my iPizzle ringy dingy device.... Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=8#findComment-474248 Share on other sites More sharing options...
July 21, 20159 yr Author comment_474250 On 7/21/2015 at 10:47 AM, rossiz said: it is - you have to rotate the propeller shaft to get the u-joint to open up for a wrench. pita, but doable.I was hoping I could get an impact in there with a u-joint socket... Oh well. Might need to jack the back end up a little higher too. I don't like working with the jackstands maxed out. Luckily I have lots of scrap wood to build some platforms out of. Thanks! :tup:Sent from my iPizzle ringy dingy device.... Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=8#findComment-474250 Share on other sites More sharing options...
