November 24, 20159 yr Author comment_481573 I'll meter out the sending unit after I get it cleaned up properly. Hopefully it is still working correctly as it looks intact the throughout the electrical resistance windings. The tank is one of those things that will haunt me if I can't repair or replace it. All the work of a complete restoration but still leaving a damaged tank installed would kill me! Even if I couldn't see it. Hopefully the Texas unit I asked about will be in good shape and reasonable price to get here. It is listed as an "A" class part.... Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=26#findComment-481573 Share on other sites More sharing options...
November 24, 20159 yr comment_481581 I'd be interested in seeing the sending unit after it comes out of the CLR and is cleaned up. I have one that I haven't dealt with yet. It still moves and the wires appear intact. Not quite as crusty as yours. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=26#findComment-481581 Share on other sites More sharing options...
November 24, 20159 yr Author comment_481583 I'd be interested in seeing the sending unit after it comes out of the CLR and is cleaned up. I have one that I haven't dealt with yet. It still moves and the wires appear intact. Not quite as crusty as yours. I'll put pictures up as soon as it is out and cleaned up. Along with metering results. Edited November 24, 20159 yr by wheee! Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=26#findComment-481583 Share on other sites More sharing options...
November 26, 20159 yr Author comment_481692 Well, approx 90 ohms in the empty position and 15 ohms full. Smooth transition of resistance through the range of the sending unit. Success! Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=26#findComment-481692 Share on other sites More sharing options...
November 26, 20159 yr comment_481696 Great job on the sending unit! Impressive save. I would have punted at the first sight. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=26#findComment-481696 Share on other sites More sharing options...
November 26, 20159 yr Author comment_481697 Not like I had a lot of choice really. No replacements to be found around here.... Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=26#findComment-481697 Share on other sites More sharing options...
November 26, 20159 yr Author comment_481713 I spent a little time on the fuel pump too. I got it running this spring with a few whacks on the side but I wasn't sure how good of a shape it was in. Hooked it up on my workbench to the power supply and pumped a bucket of CLR through it. Ran like a top! Nice smooth whirrr and strong stream pressure. Didn't disassemble it but inserted the end of the pressurized air line blower into the intake end and blew all the remaining fluids out. A lot came out... I then blew air in reverse of the flow and NOTHING! Check valve works great!This is great news as I think the pump is solid! I have pics on my other camera. I will post them up later. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=26#findComment-481713 Share on other sites More sharing options...
November 26, 20159 yr comment_481726 Wow, I didn't think it would look that good. Honestly, I didn't think it could be saved. Thanks for the pics. Mine is going into CLR for a soak. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=26#findComment-481726 Share on other sites More sharing options...
November 26, 20159 yr comment_481738 Nice save. Â I have a spare. Â Maybe I'll try to revive it and then ebay it. Â Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=26#findComment-481738 Share on other sites More sharing options...
November 26, 20159 yr Author comment_481749 Got bored at lunch and ordered a Pulse Width Dimmer module and some Green LED BA9 bulbs for the instrument cluster.... $5 ebay Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=26#findComment-481749 Share on other sites More sharing options...
November 27, 20159 yr Author comment_481791 Had access to the machine shop today so I grabbed some scrap and built a spindle pin puller. Rudimentary but hopefully effective. 5/8" threaded rod drilled and tapped M12 x 1.25 in one end, inserted into 1" square tube with 3/4" washers welded on for end caps. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=26#findComment-481791 Share on other sites More sharing options...
November 27, 20159 yr Author comment_481792 Just have to get a thrust bearing.... Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=26#findComment-481792 Share on other sites More sharing options...
