February 20, 20169 yr Author comment_486846 I bought the lower quarter repair panels that wrap around and close off the bumper shock holes... Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=49#findComment-486846 Share on other sites More sharing options...
February 20, 20169 yr comment_486848 15 minutes ago, Jeff G 78 said: So, can a 280Z valence be swapped for a 240Z valence for a small bumper swap?  Most people have to weld up the bumper shock holes when they do the swap. I've wondered about this even though I currently have no desire for a rear bumper. I actually like the holes in a 280 rear valence but this was the only new valence available.  As you can see in the pic, the bumper mount indents don't line up with the screw holes on my 77'. You can see part of a screw hole on the far right side. But I suppose there is a way to firmly mount the brackets to support a 240 style bumper if it does not weigh too much. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=49#findComment-486848 Share on other sites More sharing options...
February 20, 20169 yr comment_486850 Back to Wheee!'s topic. I Don't know what price you got your tank for but I found this on Ebay.  http://www.ebay.com/itm/Datsun-12-74-7-76-280z-Coupe-EFI-Fuel-Tank-BOILED-OUT-COATED-/141894648036?hash=item21099480e4:g:CcMAAOSwX~dWsj2n&vxp=mtr  Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=49#findComment-486850 Share on other sites More sharing options...
February 20, 20169 yr Author comment_486853 I paid wayyyyyy less but I will need to coat and seal it. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=49#findComment-486853 Share on other sites More sharing options...
February 20, 20169 yr comment_486856 5 hours ago, Jeff G 78 said: So, can a 280Z valence be swapped for a 240Z valence for a small bumper swap?  Most people have to weld up the bumper shock holes when they do the swap. Interesting. Apart from visual there are some structual differences behind the valance panel. Keeping in mind the frame was altered for the extra stress of the 5mph bumpers and support for the bumper shocks. I have read one or two threads with people talking about it, but they never reported back doing it. If you are dealing with rust issues then the 240Z valance could be a good option. If you have the early model like Mark then you also have more holes to fill not just the two bumper shock holes which good make the change more interesting. I just welded plates in the bumper shock holes. One clear difference is the mounting point holes with M10 threads in the frame for the bumper brackets. The bumper mount holes are in the horizontal position on the 240Z and on the early 280Z both sides are diagonal and the later 280Z the left mount is diagonal and the right side in a wierd vertical position. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=49#findComment-486856 Share on other sites More sharing options...
February 20, 20169 yr Author comment_486862 Chas needs to write a book for us to buy.... Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=49#findComment-486862 Share on other sites More sharing options...
February 21, 20169 yr Author comment_486915 Just downloaded a bunch of pics off the shop camera. I can't edit my older posts, so here is a quick gallery of shots from the shop... Mostly pics of the car getting the undercoating removed here: Â Â Then the fuel pump and sender were cleaned up: Edited February 21, 20169 yr by wheee! Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=49#findComment-486915 Share on other sites More sharing options...
February 21, 20169 yr Author comment_486916 Now some of the media blasting process: Â These ones are a little cloudy from all the dust... Â Then the Tranny blasting!: And the floor pan removal process begins! Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=49#findComment-486916 Share on other sites More sharing options...
February 21, 20169 yr comment_486926 What is the extra piece with the yellow wire on the sender? Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=49#findComment-486926 Share on other sites More sharing options...
February 22, 20169 yr Author comment_486929 I think that is the low fuel sensor Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=49#findComment-486929 Share on other sites More sharing options...
February 22, 20169 yr comment_486930 Dad gum! That's a lot of blasting. Your respirator needs it's own respirator. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=49#findComment-486930 Share on other sites More sharing options...
February 22, 20169 yr Author comment_486934 I still have some blasting to do. But the end is in sight at least. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=49#findComment-486934 Share on other sites More sharing options...
