  On 3/3/2016 at 2:24 AM, racer47201 said:
  On 3/3/2016 at 2:09 AM, wheee! said:
13 minutes ago, wheee! said:
.... at work [emoji6]
Must be a Government worker!    LOL
Better... military!
  On 3/3/2016 at 2:30 AM, wheee! said:
Better... military!
Wheee!, as you know I have  a lot of experience being military government worker, went from being Viet Nam ere vet to "playing in the sandbox".  I am retired now livin' off the government.  LOL
Did both in Afghanistan my friend...! No pics tho... Except this one in Panjwaii
But we digress!
Here's a shot of the new fuel pump I cleaned up!
Before:
The normal saying is "pics or it didn't happen", but in this case, I trust you completely.  And thank you.:)
Nice pump. Does the check valve work?
  On 3/3/2016 at 3:14 AM, Captain Obvious said:
The normal saying is "pics or it didn't happen", but in this case, I trust you completely.  And thank you.[emoji4]
Untested still. Working on the frame etc. Tonight I did a little paint stripping off the roof...
I have a question. The driver side floor pan seems to have a lot of extra metal at the point where it meets the transmission tunnel. The passenger side seems fine. I am wondering if I have the correct floor pan?
My concern is that if I extend the metal up the tunnel, the seat supports won't fit anymore. There is about 4 inches gap at the tunnel to the curve of the floor pan. If I bend the floor pan in to meet the tunnel, the two drain plugs against the tunnel will be vertical and the entire curve will be gone. Basically the tunnel starts where the floor pan forms the U channel.
If this is normal, I understand some metal work is needed!
Edited by wheee!
