July 25, 20169 yr comment_499510 Nice work. Still a long road ahead, but you'll have a quality product in the end for sure! Yours looks about like mine was when I started. I've got about three years into the project, and I think it'll be ready this fall or early next spring. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=68#findComment-499510 Share on other sites More sharing options...
July 25, 20169 yr Author comment_499514 Keeping at it! Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=68#findComment-499514 Share on other sites More sharing options...
July 25, 20169 yr comment_499516 I think I hear a whip crackin'……... Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=68#findComment-499516 Share on other sites More sharing options...
July 25, 20169 yr comment_499518 Looks good! When you dress the welds down it will look perfect... Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=68#findComment-499518 Share on other sites More sharing options...
July 25, 20169 yr Author comment_499534 On 7/25/2016 at 10:01 PM, Patcon said: Looks good! When you dress the welds down it will look perfect...Except I burn thru half of them grrrrrr Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=68#findComment-499534 Share on other sites More sharing options...
July 25, 20169 yr comment_499538 I don't know if this will help or if it's already obvious. When I'm welding thin steel, a poor fit or a hole, when I stop welding I watch the weld cool. IMMEDIATELY when the orange color disappears and the weld turns dark I start the next weld. The weld is still hot enough that the next weld starts easily and blends in with the previous weld. Weld times are typically about a half second in duration. It's easy to develop a rhythm that will give you a flatter weld and look more like a continuous weld. Less clean up too. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=68#findComment-499538 Share on other sites More sharing options...
July 26, 20169 yr Author comment_499544 Good advice is always appreciated. I am doing just as you are saying, and the welding is going all right but I'm thinking the Miller 210 is a bit too hot even on the lowest setting. I need a smaller welder I think! Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=68#findComment-499544 Share on other sites More sharing options...
July 26, 20169 yr comment_499577 On 7/26/2016 at 12:24 AM, wheee! said: Good advice is always appreciated. I am doing just as you are saying, and the welding is going all right but I'm thinking the Miller 210 is a bit too hot even on the lowest setting. I need a smaller welder I think! I used a 135 amp from Eastwood. It worked pretty well. With regards to grinding and dressing those welds, keep in mind where you're working. Everything you're welding is gonna be hidden so you don't need to kill yourself making them pretty. Right doesn't have to be pretty. IMHO that's why you start on the bottom of the car. Make the mistakes and learn where it won't show so that you know what you're doing when you get to the stuff that does show. Anyway, it looks great, but get a new dust mask! Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=68#findComment-499577 Share on other sites More sharing options...
July 26, 20169 yr Author comment_499578 On 7/26/2016 at 1:06 PM, ksechler said: I used a 135 amp from Eastwood. It worked pretty well. With regards to grinding and dressing those welds, keep in mind where you're working. Everything you're welding is gonna be hidden so you don't need to kill yourself making them pretty. Right doesn't have to be pretty. IMHO that's why you start on the bottom of the car. Make the mistakes and learn where it won't show so that you know what you're doing when you get to the stuff that does show. Anyway, it looks great, but get a new dust mask! Maybe I'm being a little too OCD but I would like the bottom of the car to be smooth and pretty. That's where any bad welds would be seen versus under the jute and carpet. The welds on the inside will be more structural for sure. Not necessarily lumpy and bad, but not ground flush and smooth. I still need to make sure the floor supports will fit too. and yeah, I have a box of dust masks... Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=68#findComment-499578 Share on other sites More sharing options...
July 26, 20169 yr comment_499591 On 7/26/2016 at 1:44 PM, wheee! said: Maybe I'm being a little too OCD but I would like the bottom of the car to be smooth and pretty. That's where any bad welds would be seen versus under the jute and carpet.... It's your project! We all have our own thresholds for perfection. Lord knows I spent a lot of time restoring bits and pieces that will never see the light of day because I wanted them just so (see my parking brake linkage?). Personally if some joker gets down on the ground and tries to crawl under my car to criticize my welding I think I'll just stomp him! Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=68#findComment-499591 Share on other sites More sharing options...
July 26, 20169 yr comment_499602 On 7/26/2016 at 4:13 PM, ksechler said: because I wanted them just so (see my parking brake linkage?). Yeah but when your under there doing some maintenance, it will be a joy to work on! Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=68#findComment-499602 Share on other sites More sharing options...
July 27, 20169 yr Author comment_499626 With all the techno toy tuning and Arizona z car goodies going under there, I will be showing it off I'm sure... Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=68#findComment-499626 Share on other sites More sharing options...
