August 3, 20177 yr comment_527259 im curious as to why you have 2 brake distribution blocks? Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=125#findComment-527259 Share on other sites More sharing options...
August 3, 20177 yr Author comment_527260 Stock configuration for the 280's.... Edit: not two proportioning blocks. One distribution sensor and one proportioning. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=125#findComment-527260 Share on other sites More sharing options...
August 3, 20177 yr comment_527263 21 minutes ago, wheee! said: Stock configuration for the 280's.... odd...... Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=125#findComment-527263 Share on other sites More sharing options...
August 3, 20177 yr comment_527265 The first block (the one closest to the master cylinder) is the brake warning switch. It doesn't proportion, it just lights the warning light if there's a failure in one axle of the system. The second block (the one on the firewall) does the proportioning. It's a little weird looking, but since the warning switch is mounted close to the LF wheel, they pulled the line off there to go to that corner. The pressure there will be the same as the RF, but it was just easier to pull the plumbing connection off there instead of pulling another front connection off the proportioning valve and backtracking to the LF corner. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=125#findComment-527265 Share on other sites More sharing options...
August 3, 20177 yr Author comment_527266 Correct. It senses loss of fluid pressure in front or rear brakes and shuttles braking power to the working half of the car. The warning light comes on to indicate failure. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=125#findComment-527266 Share on other sites More sharing options...
August 3, 20177 yr comment_527271 Have you ever had a complete failure of half the system while driving? I never have, but somehow I just doubt I would have the wherewithal to pump the brakes to shuttle the plunger to the end: Pedal goes to the floor. Brain goes "OH SHITE!!" and I freeze looking for an exit path. Foot planted hard on the floor. In fact, at that point, I'm probably trying to push the pedal THROUGH the floor. Brain never goes "Just pump the brakes a couple times to shuttle that plunger to the end of travel and you'll get some pressure back". Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=125#findComment-527271 Share on other sites More sharing options...
August 3, 20177 yr Author comment_527272 So funny and so true! Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=125#findComment-527272 Share on other sites More sharing options...
August 3, 20177 yr comment_527273 Haha! Oh yeah. and the final step. Look for a store to stop to buy a new pair of underwear before I get home. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=125#findComment-527273 Share on other sites More sharing options...
August 3, 20177 yr Author comment_527279 Reference info... Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=125#findComment-527279 Share on other sites More sharing options...
August 3, 20177 yr comment_527297 I may have missed it but what did you spray the interior with? It looks like a silver from the pics Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=125#findComment-527297 Share on other sites More sharing options...
August 3, 20177 yr comment_527299 15 hours ago, wheee! said: Actually your picture shows exactly where I wanted place it and how much clearance there will be. The left side of the regulator is blocked off, the right side is input from fuel rail and the bottom is return to tank. The battery cables will run beside and to the left of the regulator pretty cleanly I think! Makes sense. Â Let me know if you want me to shoot any other under hood pictures to help you place things. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=125#findComment-527299 Share on other sites More sharing options...
August 3, 20177 yr Author comment_527301 I may have missed it but what did you spray the interior with? It looks like a silver from the picsThe interior is painted with silver POR Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=125#findComment-527301 Share on other sites More sharing options...
