1976 280Z Restoration Project
wheee!
Bolted the Wilwood prop valve to the Nabco warning light distribution block.
Routed the rear brake lines back to the stock prop valve.
And yes, that is a bit of paint that peeled where a residual drop of brake fluid from the master cylinder fell onto the front rail. I will have to touch that up later... [emoji35]
  • Who's Online   2 Members, 0 Anonymous, 671 Guests (See full list)
