September 6, 20177 yr Author comment_529732 On 9/6/2017 at 1:25 AM, rcb280z said: Yes please, details on the coilovers. Wonder how old those outer tierods are. No grease zerks. The boots look deflated too. Just an observation. Wonder how long the PO drove it that way. Inner and outer tie rods will be replaced along with full GTX lower control and tension rods. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=130#findComment-529732 Share on other sites More sharing options...
September 6, 20177 yr Author comment_529785 Next up, the Techno Toy Tuning order. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=130#findComment-529785 Share on other sites More sharing options...
September 6, 20177 yr comment_529791 Lots of pretty hardware!! Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=130#findComment-529791 Share on other sites More sharing options...
September 6, 20177 yr Author comment_529793 Yup. Most of the expensive stuff for sure. I'm hoping to resurrect a lot of the original parts other than these critical components. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=130#findComment-529793 Share on other sites More sharing options...
September 9, 20177 yr Author comment_529969 Sometimes a little carnage is fun.. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=130#findComment-529969 Share on other sites More sharing options...
September 10, 20177 yr Author comment_530000 Got busy with the suspension modification...First up, I drilled two opposite holes near the top of the strut to drain the oil. The gland nuts are rusted and seized and I don't plan on saving these anyways. Drained the oil to make it safe to cut with the angle grinder/cutoff tool. Then I removed all the hub and rotor components off the front spindle. For the rears, I pushed the spindles out with the press before removing the backing plates. That gave me something to push against. Removed the backing plates and then marked out the cutoff point at 2" from the bottom. Cut off the strut and test fit the collar. I may remove a little more material for a more flush fit. Did the same to the fronts. A little more creative cutting is needed to clear the spindle hub. Not impossible but the casing needs to be cut up a bit more to get the grinder in there. And that's it for now.... Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=130#findComment-530000 Share on other sites More sharing options...
September 10, 20177 yr comment_530004 I might suggest leaving the collar up from the cast base by 1/4-3/8 or so and welding it to the tube rather than the cast base. I think the weld will be stronger. Depends on your welding skills I suppose. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=130#findComment-530004 Share on other sites More sharing options...
September 10, 20177 yr Author comment_530006 Good point. The sleeve is bevelled too so it makes a good channel for welding. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=130#findComment-530006 Share on other sites More sharing options...
September 12, 20177 yr Author comment_530116 Cleaned up the fronts. Good gap. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=130#findComment-530116 Share on other sites More sharing options...
September 14, 20177 yr Author comment_530287 Techno Toy order placed! woot woot Hope I get the credit card statement before the wife sees it.... Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=130#findComment-530287 Share on other sites More sharing options...
September 14, 20177 yr comment_530323 Oh man if my wife ever sees my stack of receipts I have hidden in the garage, I'm a dead man Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=130#findComment-530323 Share on other sites More sharing options...
September 15, 20177 yr Author comment_530326 We can move in together, cut costs... Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=130#findComment-530326 Share on other sites More sharing options...
