November 22, 20177 yr Author comment_535603 It is a huge benefit having the rotisserie in the shop! Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=136#findComment-535603 Share on other sites More sharing options...
November 22, 20177 yr Author comment_535604 Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=136#findComment-535604 Share on other sites More sharing options...
November 22, 20177 yr Author comment_535613 Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=136#findComment-535613 Share on other sites More sharing options...
November 22, 20177 yr comment_535625 I am getting ready to build a rotisserie may I ask on your rotisserie what the distance is from the top of your horizontal front/rear to the lower side of the pivot? Are you using the bumper mounts at both ends? Any drop from the pivot or just straight? Thank you Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=136#findComment-535625 Share on other sites More sharing options...
November 23, 20177 yr Author comment_535633 This is a dead simple rotisserie. No drop or balance, just a welded angle iron beast bolted to the bumper mounts. Front is bolted to the 76 shock mounts and the rear is bolted to the bottom valance bumper mounts as used by the 240’s. I welded in the openings from the rear bumper shock mounts. I will get some measurements for you. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=136#findComment-535633 Share on other sites More sharing options...
November 23, 20177 yr comment_535683 Looking great! Hopefully you won't have any issues with the vinyl kit over those rear shock towers, mine were so tight that I ripped one and I didn't have any sound deadening material on them. Hope all is well! Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=136#findComment-535683 Share on other sites More sharing options...
November 23, 20177 yr Author comment_535684 Looking great! Hopefully you won't have any issues with the vinyl kit over those rear shock towers, mine were so tight that I ripped one and I didn't have any sound deadening material on them. Hope all is well!No issue as I am going carpet over the towers and wheel humps! Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=136#findComment-535684 Share on other sites More sharing options...
November 23, 20177 yr Author comment_535685 I am getting ready to build a rotisserie may I ask on your rotisserie what the distance is from the top of your horizontal front/rear to the lower side of the pivot? Are you using the bumper mounts at both ends? Any drop from the pivot or just straight? Thank you 50” from floor to pivot point. The ceiling is only 8’ so it’s tight. But it works! Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=136#findComment-535685 Share on other sites More sharing options...
November 23, 20177 yr Author comment_535689 Sound mat complete! Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=136#findComment-535689 Share on other sites More sharing options...
November 23, 20177 yr comment_535690 Thank you very much for those measurements. Your work is a inspiration for me and my 72. Again thank you. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=136#findComment-535690 Share on other sites More sharing options...
November 23, 20177 yr comment_535692 On 11/20/2017 at 8:22 PM, wheee! said: I know how much I hated dealing with that stuff, and that was just on doors. Wow! Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=136#findComment-535692 Share on other sites More sharing options...
November 23, 20177 yr Author comment_535693 I am glad it’s mostly over. Still the doors to do.... Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=136#findComment-535693 Share on other sites More sharing options...
