January 20, 20187 yr comment_540296 On 1/19/2018 at 11:39 PM, wheee! said: Brand new from TTT. Wow, $$$! Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=153#findComment-540296 Share on other sites More sharing options...
January 20, 20187 yr comment_540300 On 1/20/2018 at 5:34 PM, rcb280z said: Wow, $$$!That price is for both so it’s about what you would pay at any parts store, if you were only buying inner tie rod ends shipping would make them more expensive but if you are already getting other things from T3 then not a big deal.Sent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=153#findComment-540300 Share on other sites More sharing options...
January 20, 20187 yr comment_540305 When they were available I never paid that much. Its been a number of years but I know I didn't pay that much for them. Like TTT's site says "For inner tie rods, these are pricey, we know, but there is only one option on the market". That is why they are so expensive. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=153#findComment-540305 Share on other sites More sharing options...
January 20, 20187 yr Author comment_540334 I don’t plan on having to replace them again... Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=153#findComment-540334 Share on other sites More sharing options...
January 20, 20187 yr comment_540337 For what it’s worth you can get the exact same part by Rare Parts at carpartsdiscount for about $64 each. I have bought these from them in the past without issue. https://www.carpartsdiscount.com/tie-rod-steering-end.html?3593=37540Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=153#findComment-540337 Share on other sites More sharing options...
January 21, 20187 yr comment_540360 Great info Mike! Thanks. I was ready to order the TTT ones but I'll check to see if the other guys have them. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=153#findComment-540360 Share on other sites More sharing options...
February 5, 20187 yr Author comment_541592 Been working on getting the stubs ready for new bearings. Ordered the bearings last week. These look pretty nice! New studs to go in too. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=153#findComment-541592 Share on other sites More sharing options...
February 5, 20187 yr Author comment_541608 I think I’ll leave the hubs mounted for the bearing install. I have a bearing and race seating kit with an impact adapter. Should work fine. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=153#findComment-541608 Share on other sites More sharing options...
February 6, 20187 yr Author comment_541656 Death by a thousand restorations... worked on the battery bracket tonight. It was previously powder coated so it took a long time to strip and prep. It looks great but that was 3 hours of work tonight! Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=153#findComment-541656 Share on other sites More sharing options...
February 6, 20187 yr comment_541666 Yep, sounds familiar. Have you started doing zinc on all the various bits and pieces? That takes a while too. Nothing worse than setting your mind to putting some assembly back together only to find some rusty spring or washer that you missed. How are you planning on doing the zinc part? Do you have a small media blasting cabinet? I would blast the small parts, zinc them and them throw them in my tumbler with corn cob media for an hour or two. They'd come out nice and shiny. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=153#findComment-541666 Share on other sites More sharing options...
February 6, 20187 yr Author comment_541668 After a lot of soul searching and hand wringing I came to a conclusion.... I won’t be plating any hardware. My car has so many mods on it already that came with stainless fittings, I will probably end up with most of my hardware in stainless. Almost everything else is getting powder coated. The stand up blast cabinet I have is doing a great job so far. Powder coating is beautiful and durable too. It also does a great job on springs. Remains flexible. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=153#findComment-541668 Share on other sites More sharing options...
February 6, 20187 yr comment_541680 On 2/6/2018 at 1:34 PM, wheee! said: After a lot of soul searching and hand wringing I came to a conclusion.... I won’t be plating any hardware. My car has so many mods on it already that came with stainless fittings, I will probably end up with most of my hardware in stainless. Almost everything else is getting powder coated. The stand up blast cabinet I have is doing a great job so far. Powder coating is beautiful and durable too. It also does a great job on springs. Remains flexible. Sounds sensible. I probably would have powder coated too if I'd had a setup for it. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=153#findComment-541680 Share on other sites More sharing options...
