February 13, 20187 yr comment_542206 Little bit of digging and I found a grubby little yellow post-it with Rockford 430-10. They made them for nissan, subaru and many other models. They should fit and cost here in NL €29.50 each. Cup diameter: 22mm Distance between circlip outer edges: 35.7mm (standard circlips) @wheee! Mark, If your uni's are stuffed, can you dismantle one and take some accurate measurements? I have some other part numbers with slightly wider/narrower dimensions. Edited February 13, 20187 yr by EuroDat Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=155#findComment-542206 Share on other sites More sharing options...
February 13, 20187 yr comment_542207 MSA has them for $299. With replaceable joints. They must have a shop that makes them up. I looked yesterday, it's on page 2 of the search results. From what I've read about replacements shafts some of them come without the dirt shield and leave the slip yoke exposed. Something to be aware of. Other issues besides just getting the old joints out and the new ones in, with either of the possible methods for keeping them in, are balancing. By the time it's a done, it's still just a part you can't see, that could end up causing vibration problems. Seems like a high risk-reward ratio to try it yourself. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=155#findComment-542207 Share on other sites More sharing options...
February 13, 20187 yr Author comment_542210 I will press out the old u joints and take some measurements. It looks like the 430-10 Rockwell's are the ones I see listed as fitting. (according to Rockwell) Edited February 13, 20187 yr by wheee! Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=155#findComment-542210 Share on other sites More sharing options...
February 13, 20187 yr comment_542220 Nice work. I had a list with yhe 720 pick up and as far as I could tell, the 720 had the same staked uni-joints. Would be good to have an alternative. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=155#findComment-542220 Share on other sites More sharing options...
February 13, 20187 yr comment_542222 They write like replacing a staked-in joint is a common thing. I have seen kits for other brands of cars, that come with a little grinding/cutting tool that cuts out the stake. But if I recall correctly the yokes for those kits had a groove already in place, that was used for a circlip afterward. Kind of like the manufacturer staked in a clipped u-joint for some reason. Cut out the stakes and use the old clips. Looks like a fun project anyway. http://www.theujointstore.com/43010.html Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=155#findComment-542222 Share on other sites More sharing options...
February 13, 20187 yr comment_542224 Found the kit. You can see the groove in his pictures. https://www.f150forum.com/f72/replacing-staked-u-joints-175529/ Who knows, maybe Nissan ground the flats on the inside of the yoke for an internal clip, but then staked it in. Can't tell what kind of clips the 43-010 uses. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=155#findComment-542224 Share on other sites More sharing options...
February 13, 20187 yr comment_542229 Not to clutter but I thought this document was interesting. It mentions the crimping. I searched the number on the end of your u-joint. http://www.farnell.com/datasheets/78011.pdf Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=155#findComment-542229 Share on other sites More sharing options...
February 13, 20187 yr Author comment_542232 Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=155#findComment-542232 Share on other sites More sharing options...
February 13, 20187 yr comment_542233 Do the grooves match your yokes? Stalking... Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=155#findComment-542233 Share on other sites More sharing options...
February 13, 20187 yr Author comment_542234 Will have to check when I am home again... darn day job in the way again! I won't have the bearings for awhile yet anyways. I will press out the old one regardless and get pics etc. Edited February 13, 20187 yr by wheee! Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=155#findComment-542234 Share on other sites More sharing options...
February 14, 20187 yr comment_542251 8 hours ago, wheee! said: It looks like the 430-10 Rockwell's are the ones I see listed as fitting. (according to Rockwell) Just remembered some funny fit business with CV axles, from the past. When I did a Google on it I found that it's actually gotten worse. Used to be just a specialty axle house, now it's Autozone. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=155#findComment-542251 Share on other sites More sharing options...
February 14, 20187 yr Author comment_542259 Here’s some shots of the separated joint. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=155#findComment-542259 Share on other sites More sharing options...
