January 29, 20196 yr comment_566914 Holy crap batman! I'm scared for you! I wouldn't know where to began with all that wire. Hope it's all laid out in the instructions. Good luck Mark. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=192#findComment-566914 Share on other sites More sharing options...
January 29, 20196 yr comment_566916 That doesn’t look like much fun LOL! Enjoy! Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=192#findComment-566916 Share on other sites More sharing options...
January 29, 20196 yr comment_566924 If a Luddite like me can do it, you won't have a problem, does Haltech send you the unit with tune already installed or are they tuning it remotely as you drive? Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=192#findComment-566924 Share on other sites More sharing options...
January 29, 20196 yr Author comment_566926 If a Luddite like me can do it, you won't have a problem, does Haltech send you the unit with tune already installed or are they tuning it remotely as you drive?It needs tuning? Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=192#findComment-566926 Share on other sites More sharing options...
January 29, 20196 yr Author comment_566930 Some more cleanup and progress... Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=192#findComment-566930 Share on other sites More sharing options...
January 30, 20196 yr Author comment_566997 Now to find my two pin tools... And order some U joints! Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=192#findComment-566997 Share on other sites More sharing options...
January 30, 20196 yr Author comment_566998 Driveshaft comparison pic... Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=192#findComment-566998 Share on other sites More sharing options...
February 2, 20196 yr Author comment_567287 Time for a mythbusters episode! The half shafts are absolutely identical. No one side longer or shorter than the other. @zKars Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=192#findComment-567287 Share on other sites More sharing options...
February 2, 20196 yr Author comment_567289 And before anyone starts saying “but those are 280 shafts....!” I pulled apart a 240 shaft I had laying around (yea it’s a 240 cuz the stub shaft is attached and the spline count is for a 240...) and they are the same as the 280 ones. The 240 shaft with u joint still attached on top. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=192#findComment-567289 Share on other sites More sharing options...
February 2, 20196 yr comment_567312 John Coffey had a nice writeup about this on his old Beta Motorsports web page. He even transferred it over to the Facebook of his new company when he shut Beta down. They compared a whole bunch of shafts to show that they're all the same length. The only reason for binding then is if there's less space between the hubs of a 240Z versus a 280Z. The 240Z hubs, actually the distance between the flanges, would actually have to thicker since the wheel bases are the same. That's the number that is still unclear. So, comparing the flange to flange distance of a 240Z rear axle to a 280Z rear axle might show something. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=192#findComment-567312 Share on other sites More sharing options...
February 2, 20196 yr comment_567313 Here's an old thread about it - https://forums.hybridz.org/topic/60419-halfshaft-length-and-r200-swap/ Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=192#findComment-567313 Share on other sites More sharing options...
February 2, 20196 yr comment_567316 How much grease was in those half shafts? They look like they have gotten a little warm at some time Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=192#findComment-567316 Share on other sites More sharing options...
