February 13, 20196 yr Author comment_568203 Marginally better than the original power plant... Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=196#findComment-568203 Share on other sites More sharing options...
February 13, 20196 yr comment_568212 What are you doing for the heater hoses down the passenger side of the block? I see some brass fittings in there. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=196#findComment-568212 Share on other sites More sharing options...
February 13, 20196 yr Author comment_568214 On 2/13/2019 at 1:04 PM, Patcon said: What are you doing for the heater hoses down the passenger side of the block? I see some brass fittings in there. Those are transport plugs. The engine came to me in the back of a pickup truck and needed to have a couple plugs to prevent leaks from the residual coolant. I left them in to keep contaminants out for now. I took the hose plug off for the pictures. The stock lines will run as normal under the COP setup. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=196#findComment-568214 Share on other sites More sharing options...
February 14, 20196 yr comment_568263 On 2/13/2019 at 2:26 PM, wheee! said: Those are transport plugs. The engine came to me in the back of a pickup truck and needed to have a couple plugs to prevent leaks from the residual coolant. I left them in to keep contaminants out for now. I took the hose plug off for the pictures. The stock lines will run as normal under the COP setup. I had SS hose fittings in the heater in/out-lets. Both BSPT and NPT have 14 TPI for these 1/2 threads so it fits without drama. The 280's have the threaded heater hose fitting on the lower rad outlet, and the hole at the back of the head is always threaded, so it's an easy conversion. Makes it easy to put a simple brass plug in it. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=196#findComment-568263 Share on other sites More sharing options...
February 14, 20196 yr comment_568266 Most people in my part of the world wouldn't know what a transport plug is. The engine just ends up in the back of a truck and what comes out, comes out! Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=196#findComment-568266 Share on other sites More sharing options...
February 14, 20196 yr Author comment_568268 There was however a mystery hole in the side of the head that was tapped and led to a coolant passage. That leaked a little and surprised me as it was definitely someone’s mod. Jim wasn’t tracking it either as it lays beneath the intake manifold gasket. You can see it beneath the 4&5 intake ports. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=196#findComment-568268 Share on other sites More sharing options...
February 14, 20196 yr Author comment_568269 I have since plugged it with threaded aluminum rod. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=196#findComment-568269 Share on other sites More sharing options...
February 14, 20196 yr comment_568278 On 2/14/2019 at 1:28 AM, Patcon said: Most people in my part of the world wouldn't know what a transport plug is. The engine just ends up in the back of a truck and what comes out, comes out! It's the same here except you might find bits of an old T-shirt stuffed here and there. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=196#findComment-568278 Share on other sites More sharing options...
February 14, 20196 yr Author comment_568283 It’s amazing the stuff that eats your time. Tonight I spent three hours in the shop working on a couple little things. One of which is the oil pan reinforcing ring with the exhaust standoff. It had been crunched a bit and needed some love. So after media blasting, bending, anvil hammering and more media blasting, welding, more media blasting... it looks acceptable! No pics but I thought it was funny how much time that took... Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=196#findComment-568283 Share on other sites More sharing options...
February 14, 20196 yr Author comment_568284 Here’s the piece I’m talking about. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=196#findComment-568284 Share on other sites More sharing options...
February 14, 20196 yr Author comment_568341 So this is definitely going onto my car somewhere!Leopard 2 Main Battle Tank breather fitting! All Z cars should have tank parts...GPMG C6 Machine gun 7.62mm round for scale.... [emoji51] Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=196#findComment-568341 Share on other sites More sharing options...
February 14, 20196 yr comment_568363 On 2/14/2019 at 9:03 PM, wheee! said: So this is definitely going onto my car somewhere! Leopard 2 Main Battle Tank breather fitting! All Z cars should have tank parts... GPMG C6 Machine gun 7.62mm round for scale.... Cody loves that! Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=196#findComment-568363 Share on other sites More sharing options...
