March 11, 20196 yr Author comment_570691 I could.... but I don't really want to... Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=208#findComment-570691 Share on other sites More sharing options...
March 12, 20196 yr comment_570776 Not to be "that guy" but the connection of your braided fuel line below the regulator to the hard fuel line concerns me a little. I see you have it hose clamped. Braided fuel line doesn't clamp very well especially for higher pressure systems used with fuel injection. Please double check that so your sure of it. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=208#findComment-570776 Share on other sites More sharing options...
March 12, 20196 yr Author comment_570779 I hear you... I am looking for some hard line to AN6 fittings as we speak. It is on my to do list! Edit: You spurred me to action and i finally got them ordered today.  ? Edited March 12, 20196 yr by wheee! Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=208#findComment-570779 Share on other sites More sharing options...
March 12, 20196 yr Author comment_570799 The funny thing is that the factory used clamps all over the FI lines.... Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=208#findComment-570799 Share on other sites More sharing options...
March 13, 20196 yr Author comment_570841 Dropped the oil pan tonight and cleaned it out. Some media blasting and a day at the parts spa will clean it up ready for powder coating! Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=208#findComment-570841 Share on other sites More sharing options...
March 13, 20196 yr Author comment_570855 Surprised at the amount of pitting I found on the bottom of the pan!Guess we will see how it looks after powder coating. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=208#findComment-570855 Share on other sites More sharing options...
March 13, 20196 yr comment_570860 Wow. That's some pitting. Are you sure none of those pits go all the way through? Was there oil in the pan in recent past, or did you purchase it dry? 18 hours ago, wheee! said: The funny thing is that the factory used clamps all over the FI lines.... Yeah, that was my reaction as well. @ksechler did specifically say the braided lines didn't clamp well. Maybe the non-braided original lines aren't a problem? Hopefully he'll chime back in with more info? Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=208#findComment-570860 Share on other sites More sharing options...
March 13, 20196 yr Author comment_570871 44 minutes ago, Captain Obvious said: Wow. That's some pitting. Are you sure none of those pits go all the way through? Was there oil in the pan in recent past, or did you purchase it dry? Yeah, that was my reaction as well. @ksechler did specifically say the braided lines didn't clamp well. Maybe the non-braided original lines aren't a problem? Hopefully he'll chime back in with more info? The inside of the pan is flawless, no issues. The metal is very thick on the bottom of the pan and I was surprised at it's dry weight. It is cosmetic damage I'm sure but I may pick up another pan to refinish in better condition. I like the idea of the hard line to AN fittings anyways, so I ordered them just because... as for the braided line, it is a rubber line on the inside (not PTFE) , surrounded by steel reinforcing wire and fibre braid. A clamp would still hold it fine, I'm sure. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=208#findComment-570871 Share on other sites More sharing options...
March 13, 20196 yr comment_570890 5 hours ago, Captain Obvious said: Wow. That's some pitting. Are you sure none of those pits go all the way through? Was there oil in the pan in recent past, or did you purchase it dry? Yeah, that was my reaction as well. @ksechler did specifically say the braided lines didn't clamp well. Maybe the non-braided original lines aren't a problem? Hopefully he'll chime back in with more info? When doing my own fuel system I did some research and found that hose clamps aren't recommended for braided line especially when using fuel injection. The line is too stiff and it doesn't compress well, I guess. Also there is a specific type of flare that is supposed to be used. I didn't have the tool to do the flare. I ended up using a compression fitting instead.  Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=208#findComment-570890 Share on other sites More sharing options...
March 13, 20196 yr Author comment_570893 @ksechler  I miss reading your build thread.... Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=208#findComment-570893 Share on other sites More sharing options...
March 13, 20196 yr comment_570895 16 minutes ago, ksechler said: When doing my own fuel system I did some research and found that hose clamps aren't recommended for braided line especially when using fuel injection. The line is too stiff and it doesn't compress well, I guess. Also there is a specific type of flare that is supposed to be used. I didn't have the tool to do the flare. I ended up using a compression fitting instead.  Could your research have been about steel braid, not cloth? Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=208#findComment-570895 Share on other sites More sharing options...
March 13, 20196 yr Author comment_570897 This is the type of line I am using. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=208#findComment-570897 Share on other sites More sharing options...
