April 6, 20205 yr Author comment_596519 Installed the 3 Row Champion radiator. I got a crazy deal on it a long time ago and it is for a 280ZX but the only difference is the centre drain. I modded the splash pan to compensate and now it fits great! Â Â Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=260#findComment-596519 Share on other sites More sharing options...
April 6, 20205 yr Author comment_596520 I refurbished the horns a while ago and mounted them up! Â Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=260#findComment-596520 Share on other sites More sharing options...
April 6, 20205 yr Author comment_596526 Condenser brackets fabricated and installed. Sent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=260#findComment-596526 Share on other sites More sharing options...
April 6, 20205 yr Author comment_596538 Finished routing the AC lines and used the quikclip kit to attach all the fittings. 10 from the evaporator to the pump, 8 to the top of the condenser, 6 from the condenser to the drier, 6 from the dryer to the evaporator. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=260#findComment-596538 Share on other sites More sharing options...
April 6, 20205 yr Author comment_596542 Air filter in, rad hoses in place and things are starting to look like they’re supposed to!   Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=260#findComment-596542 Share on other sites More sharing options...
April 6, 20205 yr comment_596547 Turn the key, Turn the key! Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=260#findComment-596547 Share on other sites More sharing options...
April 6, 20205 yr Author comment_596548 Turn the key, Turn the key!This car has no keys... [emoji1]Sent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=260#findComment-596548 Share on other sites More sharing options...
April 8, 20205 yr Author comment_596690 So here’s something cool. I have a couple sets of the rear tail light finishers and none are great. I tested a small broken piece by first media blasting it gently, then spraying it with Duplicolor Graphite wheel paint and right beside that, some commercial chrome spray paint. I think I can live with this until I can afford re-chromed bezels....! Edited April 8, 20205 yr by wheee! Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=260#findComment-596690 Share on other sites More sharing options...
April 8, 20205 yr comment_596694 On 4/6/2020 at 8:26 PM, wheee! said: This car has no keys... Sent from my iPhone using Tapatalk A key point! Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=260#findComment-596694 Share on other sites More sharing options...
April 8, 20204 yr Author comment_596705 This is four coats of graphite. Needs to be matte cleared after this. The final result should not be glossy.  Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=260#findComment-596705 Share on other sites More sharing options...
April 9, 20204 yr comment_596724 I did that on the 77 280 and turned out quite presentable. Only another Z guy would take a 2nd look. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=260#findComment-596724 Share on other sites More sharing options...
April 9, 20204 yr Author comment_596745 Some more progress on various fronts. I have installed the refurbished factory fan clutch and fan in the car for now. I had a Ford Taurus fan from a JY but there is no way that will for between the rad and L series engine. I like the look of the factory fan in there anyways... This allowed me to install the silicone rad hoses as well. I also installed the cold air intake pipe and hose routing this was key as I had to ensure that the AC lines and the hood hinges cleared properly. Keeping with the front end theme, I spent about three hours cleaning and refurbing the front indicator housings and wires. They had been liberally coated in undercoating somehow by the PO. I will leave the lens polishing for later. The surrounds for the indicators were also somewhat chipped so I tried to use some epoxy to build up damaged areas. I will see if it held well enough to sand and paint today. I installed the centre valance to ensure it cleared the horn mounts and fit along with @EuroDat 's 240 bumper conversion kit. Of course it did! I routed my secret hood release cable into position and found a nice spot to access it in case of power loss. I started disassembling and cleaning up the taillight surrounds. While all this was going on I received a package with exhaust hangers that I will weld into place (on the pipe) to secure the exhaust pipe to the factory mounts. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=260#findComment-596745 Share on other sites More sharing options...
