1976 280Z Restoration Project
wheee!
A quick trip to the JY and I have my door grommet solution. I believe it was an older Cavalier that gave up the rear door boots.
I traced the opening size onto tape on the paint and then ground out the grommet size from that. A little permatex in behind and we are good to go!
Also, if anyone is wondering what all those white wires are for in the fusible links....
Four of them go to the starter motor positive for a straight feed from the battery cable. I replaced all of that with a new fuse block.
I need to wrap the wires and replace the cover etc, but it’s a nice mod. Voltage display for the first 30 seconds of ignition/accessory. LEDs to show fuse integrity.
So while I wait for my harness loom tape to arrive, I decided to wire in some more important mods. Thanks to the experts that came before me for the great DIY files here on the forum!
New fused relay cluster to ensure clean power to the essentials. Left to right, low beam, high beam, starter and horn.
  • Who's Online   2 Members, 0 Anonymous, 958 Guests (See full list)
