wheee! Posted August 6, 2015 Author Share #121 Posted August 6, 2015 Started welding up the holes on the intake yesterday too! Attached a brass rod to act as a heat sink near the flange TIG welded the rest of it up! More welding to do today after I ground off the beads, found a few pinholes. More pics to come! Sent from my iPizzle ringy dingy device.... Link to comment Share on other sites More sharing options...
Patcon Posted August 6, 2015 Share #122 Posted August 6, 2015 280z doors are much heavier than 240z doors. 240z doors feel like empty beer cans. They added a crash bar inside the 280z doors and it adds a lot of weight. Also if you remove them with the window and frames on them that adds too. I would love to learn how to TIG... Link to comment Share on other sites More sharing options...
wheee! Posted August 6, 2015 Author Share #123 Posted August 6, 2015 Me too! That is my buddy Hayden doing the welding. I am an appreciative spectator....! Link to comment Share on other sites More sharing options...
wheee! Posted August 6, 2015 Author Share #124 Posted August 6, 2015 One more pass at the welder to finish it I think. I want to start polishing this ASAP. Sent from my iPizzle ringy dingy device.... 1 Link to comment Share on other sites More sharing options...
Patcon Posted August 6, 2015 Share #125 Posted August 6, 2015 I love how a cleaned up intake looks. Almost as good as triples ... I am so conflicted! 1 Link to comment Share on other sites More sharing options...
rossiz Posted August 7, 2015 Share #126 Posted August 7, 2015 looks great - nice work.while you have the doors off, cover the inside of the skins with a soundproofing material and you will be happy with how much quieter the cabin gets. also much more solid sounding when closing.i used a foil-backed adhesive mat for the entire floor/trans tunnel, roof, doors and hatch floor and really love the results. Link to comment Share on other sites More sharing options...
wheee! Posted August 7, 2015 Author Share #127 Posted August 7, 2015 I was going to sound deaden the car for sure. Also was considering the home made lizard skin to replace the asphalt mat liner from the factory. Sent from my iPizzle ringy dingy device.... Link to comment Share on other sites More sharing options...
Patcon Posted August 7, 2015 Share #128 Posted August 7, 2015 I just bought the lizard skin instead of DIY route. I used the insulating lizard skin first then the sound deadening product. Just be sure when you spray that you get enough on so it lays out smooth or even orange peelie. I may even top that with Dyno mat. The car is already much quieter sounding. 1 Link to comment Share on other sites More sharing options...
wheee! Posted August 10, 2015 Author Share #129 Posted August 10, 2015 Manifold is all welded up and sanded... Just the polishing left now! Sent from my iPizzle ringy dingy device.... 3 Link to comment Share on other sites More sharing options...
racer47201 Posted August 10, 2015 Share #130 Posted August 10, 2015 Dang that looks nice. What did you do to it togetting to look so good. How many hourrs? Link to comment Share on other sites More sharing options...
wheee! Posted August 10, 2015 Author Share #131 Posted August 10, 2015 Die grinder air tool, dremel with sanding wheels, TIG welder, random orbital air sander, cutoff wheels on 5" grinder, aluminum grinder wheels, various emery cloth hand sanding, one inch strip see saw sanding around the tubes.... 50 hrs plus. So far...Sent from my iPizzle ringy dingy device.... Link to comment Share on other sites More sharing options...
Patcon Posted August 11, 2015 Share #132 Posted August 11, 2015 Art takes time... lots of time... 1 Link to comment Share on other sites More sharing options...
