We Need Your Help! ×
1976 280Z Restoration Project
wheee!
One disappointment was one of the front indicators was corroded badly on the inside. The entire reflector surface was a rusted crumbling mess. I will need to source a new one of those. Or switch to 240 indicator lights...
I still like the look of the 280 ones though.
Sent from my iPizzle ringy dingy device....
I had the samd problem with mine I repaired the reflector section in a thread on this forum. If you can"t find a good set or repair yours pm me.
Chas
Edit: link added http://www.classiczcars.com/topic/47973-280z-front-turn-signal-refresh/
Edited by EuroDat
Small progress again with the intake. Tapped in new ports for vacuum on the back of the manifold. Added a port for the brake booster under the manifold to come out above the heat shield. Still need to get the welding done!
Chas
Thanks for the link Chas! I will check the reflector again. I think ALL the metal is gone though.... Just the plastic left.
Does anyone have experience with the 11mm Pallnet fuel rail on our stock intacke manifold? I am interested in using the o-ring style rail to clean things up and I have heard that the Toyota 11mm injectors will work.... any feedback?
part number 23250 45011, low ohms, 190cc
I think Zed heax or Captain have a set-up with o-ring injectors. I can't remember who. Maybe they will tell you there experience.
I thought pallnet made a version for o-rings and a special mounting kit to fix it to the manifold.
There is a thread here about it.
I have all the info from pallnet except personal experience with the 11mm o-ring injectors mentioned above.
A member on hybridZ may have some feedback for me soon. JavelinZ I think.
Pallnet will be providing all the other goodies to go on my stock intake.
