'72 240Z Rebuild
siteunseen
If those two were sitting in front of me I'd measure resistance to ground through F and N on both. If they're both the same and they both worked with the external regulator that would tell something.  Alternators do short internally sometimes.  Still need the right alternator though, in the long run.
Hey, I'm not sure I'm writing right.  It is clear that the 77 alternator IS NOT the alternator to use with Dave Irwin's ZXP plug, right?
Or are you still using the external regulator?  If so, that 77 alternator should function the same way, just put out more amps at full output.
When you mentioned Dave Irwin's pug, I assumed that you were using one.  Maybe not.
I don't think that's right.  Resistance between F and ground (E) should be 5 ohms, according to FSM.  If you have F connected to ground that might be your problem.  F is for Field and is a wire that gets power when the key is On.
That's not ground on the F connection. That's ground on one of the bolts that hold the two halves of the alternator together. The "F" label refers to the connection in the T connector, not that bolt head. They just put the label very close to the bolt head so you're thinking it' related. It' not.
That bolt head is ground, but ground should really be connected to the "E" screw though.
We have a Cool Hand Luke situation here.
F and N are the T plug terminals.  You circled what could be used as E, for ground (the whole case is grounded).  So that would be right.  I would take the T plug off and measure resistance to ground from each female pin.  Maybe you pinched a wire or have a short in your regulator.  Then you could also measure power there with your meter, and the key On.
Edit - added an F and N picture.
Edited by Zed Head
4 hours ago, S30Driver said:
Possibly the newer one has a serious problem.  Is it a rebuilt from a parts store?
What we have here is failure to rebuild. LOL
The new alternator is a piece of junk. Put the old one back on, turn the key and everything is fine. Hopefully they'll give me another one?
Goodnight John BoyZ!
  • Who's Online   1 Member, 0 Anonymous, 828 Guests (See full list)
