March 13, 201510 yr Author comment_465492 Compared to most other vehicles that come in, media blasting this 240Z was relatively quick and easy due to the lack of rust. We did find some areas of mild concern that we will be repairing. Â Â Edited March 13, 201510 yr by KiddysClassics Link to comment https://www.classiczcars.com/forums/topic/51064-1971-datsun-240z-restoration/?&page=2#findComment-465492 Share on other sites More sharing options...
March 16, 201510 yr Author comment_465683 These openings in the firewall were originally made to allow the HVAC lines to be run inside the vehicle. Because the owner no longer tends to use them, we fabricated patch pieces and welded them in. Â Â Link to comment https://www.classiczcars.com/forums/topic/51064-1971-datsun-240z-restoration/?&page=2#findComment-465683 Share on other sites More sharing options...
March 18, 201510 yr Author comment_465861 Upon inspection of the rear valance, we noticed that the panel was being pushed up between the spot welds - which usually indicates that there is rust beneath the surface. After carefully removing the rusted panel, it was media blasted, repaired and re-installed. Â Â Link to comment https://www.classiczcars.com/forums/topic/51064-1971-datsun-240z-restoration/?&page=2#findComment-465861 Share on other sites More sharing options...
March 18, 201510 yr comment_465862 So nice to see a Z restored "the right way". I hope your painter is as good as your body work! Link to comment https://www.classiczcars.com/forums/topic/51064-1971-datsun-240z-restoration/?&page=2#findComment-465862 Share on other sites More sharing options...
March 18, 201510 yr comment_465876 Beautiful work! Â Man is that thing clean. Â Â My Z is fairly rust free, but I think I have more rust showing then that one stripped! Edited March 18, 201510 yr by HuD 91gt Link to comment https://www.classiczcars.com/forums/topic/51064-1971-datsun-240z-restoration/?&page=2#findComment-465876 Share on other sites More sharing options...
March 18, 201510 yr comment_465903 How did you treat the bare metal between the panels? Are you TIGing or MIGing?Charles Link to comment https://www.classiczcars.com/forums/topic/51064-1971-datsun-240z-restoration/?&page=2#findComment-465903 Share on other sites More sharing options...
March 19, 201510 yr Author comment_465940 How did you treat the bare metal between the panels? Are you TIGing or MIGing?Charles Every panel prior to reassembly is first media blasted clean, if the panel is going to be welded those areas that will be affected by heat are coated in a weldable primer.  If the area is not going to be welded and/or will not be affected by the heat of the welder, such as the inside section of the new frame rails below the flange. (we will post pictures of those later after they are finished with them) Then those areas are coated with epoxy. As for our welding methods about 90% of the work we do in the shop is TIG welded.  If I can get the back side of the panel to hammer and dollie my weld seam I will always without question reach for the TIG. Link to comment https://www.classiczcars.com/forums/topic/51064-1971-datsun-240z-restoration/?&page=2#findComment-465940 Share on other sites More sharing options...
March 19, 201510 yr Author comment_465955 While inspecting the vehicle, we noticed a large rust hole under the cowl. We scraped away the seam sealer and revealed a significant amount of damage compared to the rest of the vehicle. We removed the HVAC duct and repaired it and the surrounding area. Â Â Link to comment https://www.classiczcars.com/forums/topic/51064-1971-datsun-240z-restoration/?&page=2#findComment-465955 Share on other sites More sharing options...
March 19, 201510 yr comment_465966 thanks for posting these great pics - i'm watching and learning Link to comment https://www.classiczcars.com/forums/topic/51064-1971-datsun-240z-restoration/?&page=2#findComment-465966 Share on other sites More sharing options...
April 1, 201510 yr Author comment_466888 The rear wheel well on the passenger's side was badly rusted. We cut away the damaged area and fabricated patch panels to replace it. Currently, we're working on ensuring the contours match the factory look. Link to comment https://www.classiczcars.com/forums/topic/51064-1971-datsun-240z-restoration/?&page=2#findComment-466888 Share on other sites More sharing options...
April 1, 201510 yr comment_466895 What a fabulous job you're doing here, keep the pics coming! Link to comment https://www.classiczcars.com/forums/topic/51064-1971-datsun-240z-restoration/?&page=2#findComment-466895 Share on other sites More sharing options...
April 1, 201510 yr comment_466900 Thanks for the info. I thought it looked like TIG. I have a MIG rig and have never tried TIG. Working in the front cowl area is no fun but the worked turned out well. Did you consider using the Tabco patch panels for the wheel arch and dogleg instead of fabricating from scratch? They are pretty close...Charles Link to comment https://www.classiczcars.com/forums/topic/51064-1971-datsun-240z-restoration/?&page=2#findComment-466900 Share on other sites More sharing options...
