April 2, 201510 yr Author comment_466950 With any patch panel, we look at how much time it takes to make a patch panel vs. how much it costs to buy one - many times, the aftermarket patch panels require a lot of work to make them fit to the body of the car - often taking close to the same amount of time it would have taken to fabricate a completely new one. If we see that the cost of the panel is close to the cost of the labor to create one ourselves, we often go with fabrication over purchase. However, if buying an aftermarket panel is obviously cheaper due to the complexity, we will always head in that direction or try to find a donor Link to comment https://www.classiczcars.com/forums/topic/51064-1971-datsun-240z-restoration/?&page=3#findComment-466950 Share on other sites More sharing options...
April 12, 20159 yr comment_467538 What a great thread, keep those pics coming along! Link to comment https://www.classiczcars.com/forums/topic/51064-1971-datsun-240z-restoration/?&page=3#findComment-467538 Share on other sites More sharing options...
May 11, 20159 yr Author comment_469558 Although these frame rails were not in horrible shape, the owner of the car has decided to replace the original rails with thicker aftermarket rails to make the body stiffer to support the additional horsepower the car will have once complete. Our job was to make the new frame rails replicate the original to maintain the overall stock look the customer wants to keep. Link to comment https://www.classiczcars.com/forums/topic/51064-1971-datsun-240z-restoration/?&page=3#findComment-469558 Share on other sites More sharing options...
May 12, 20159 yr comment_469587 Did you use "Bad Dog" rails? Link to comment https://www.classiczcars.com/forums/topic/51064-1971-datsun-240z-restoration/?&page=3#findComment-469587 Share on other sites More sharing options...
May 13, 20159 yr Author comment_469693 Did you use "Bad Dog" rails?Yes, they are "Bad Dog". The customer brought them in to have them custom fit to the vehicle. Link to comment https://www.classiczcars.com/forums/topic/51064-1971-datsun-240z-restoration/?&page=3#findComment-469693 Share on other sites More sharing options...
May 13, 20159 yr comment_469725 I have heard good things about their rails Link to comment https://www.classiczcars.com/forums/topic/51064-1971-datsun-240z-restoration/?&page=3#findComment-469725 Share on other sites More sharing options...
May 14, 20159 yr Author comment_469789 I have heard good things about their rails The rails are nice. Although don't reference the photos above as how they will come to you. We added to them to make them look more like the original. We also added plates to the rear frame rail to help reinforce where the frame rail ties into the rear frame cross section. As you can see from the photos below, extensive modifications were done to ensure that the rails properly fit the vehicle. Edited May 14, 20159 yr by KiddysClassics Link to comment https://www.classiczcars.com/forums/topic/51064-1971-datsun-240z-restoration/?&page=3#findComment-469789 Share on other sites More sharing options...
May 15, 20159 yr comment_469818 Looks good. Like the mods on the rails Link to comment https://www.classiczcars.com/forums/topic/51064-1971-datsun-240z-restoration/?&page=3#findComment-469818 Share on other sites More sharing options...
May 15, 20159 yr comment_469825 You do such a beautiful job! The welding is amazing, so fortunate to see a pro doing it as an inspiration and thanks for sharing. I now will look into learn how to tig weld one day... Edited May 15, 20159 yr by 240Ziggy Link to comment https://www.classiczcars.com/forums/topic/51064-1971-datsun-240z-restoration/?&page=3#findComment-469825 Share on other sites More sharing options...
May 15, 20159 yr Author comment_469866 You do such a beautiful job! The welding is amazing, so fortunate to see a pro doing it as an inspiration and thanks for sharing. I now will look into learn how to tig weld one day... Thank you for watching! If you have any questions, please don't hesitate to ask. Edited May 15, 20159 yr by KiddysClassics Link to comment https://www.classiczcars.com/forums/topic/51064-1971-datsun-240z-restoration/?&page=3#findComment-469866 Share on other sites More sharing options...
March 15, 20169 yr Author comment_489095 Work on the rear rocker corners Link to comment https://www.classiczcars.com/forums/topic/51064-1971-datsun-240z-restoration/?&page=3#findComment-489095 Share on other sites More sharing options...
