I need to build a motor for Memphis and don't want to do the stoker yet. I have a few blocks that could be over bored.
I recall some mention in the past about chevy pistons that work with over bores?
Anyone know of possible solutions?
Cast hypereutectic pistons are fine for this one.
Edited by Blue
Thanks again all!
I think I found something:
Piston pin is ~ 1.2mm bigger in diameter so rods will need boring or existing pin sleeved.
The piston bore is 89mm.
The compression height/pin height is 38.99mm
Piston to Head clearance is ~0.32mm so it needs another .07mm off the pistons.
It should have a good squish if I can find a 1mm X 89mm gasket.
post-6852-0-59435500-1425766777_thumb.jp
post-6852-0-76914700-1425766903_thumb.jp
Edited by Blue
Don't know about those Steve..........I guess he wants a block to convert to a stroker later. Swap in 240Z 9mm rods, stroker crank and 240SX pistons and you're in business after Memphis. Biggest I've ever gone on the L28 is .040 over ( 1mm ). I've never built a Stroker.......I guess it should be on my "Bucket List".
