Posted March 8, 201510 yr comment_465132 Looking for a bit of help, I'm getting rear disk conversion brackets made based on this diagram I found online. My main question is does any one know how far it needs to be machined down? The bracket has been cut from 1/2 inch steel. Thanks Sent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/51072-question-about-brake-conversion-bracket/ Share on other sites More sharing options...
March 8, 201510 yr comment_465152 Is that the bracket for the S130 caliper or the S13 caliper? Â Link to comment https://www.classiczcars.com/forums/topic/51072-question-about-brake-conversion-bracket/#findComment-465152 Share on other sites More sharing options...
March 8, 201510 yr Author comment_465154 This the maxima bracket which can be used with the early 280zx caliper I believeSent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/51072-question-about-brake-conversion-bracket/#findComment-465154 Share on other sites More sharing options...
