Lowering Springs Vs. Original Springs Height
73str86
I have a question about lowering spring height vs. (old) stock spring height. I purchased what I believed were a used set of Suspension Techniques linear lowering springs. They have ST Front stickers in front. When I compare the rear pair with my original set, the ST springs are around 3" shorter. Is this normal? I can seem to compress the original springs to the ST springs' height quite easily.
ST rear springs on left, original rear springs on right
IMAG3257
Stickers on front springs
IMAG3259
Thanks in advance.
I just measured one of my Suspension Techniques springs that is out of my car and it is a little less than 11 1/2".
I cant remember if that is the front or rear spring but it is a Suspension Techniques spring.
and you will not need a spring compressor with these springs.
Steve
Edited by nix240z
  • 4 weeks later...
Any advice on rear wheel rub? Mine are rubbing when I accelerate, hit bumps, etc... I'm not sure if coilovers can solve this or what but I'd really like to NOT cut the fenders and keep the wheels on. I'm stumped!
You can purchase universal Urethane spacers that fit on the strut under the spring. Couple of the big Urethane bushing manufacturers make them. You can also find them at Race shops that handle Circle Track Parts. Either spacers that go under the spring or " Spring rubbers " that go between the coils. Pitstop USA is one of my fave Race Parts suppliers:
http://pitstopusa.com/
Spring rubbers:
http://pitstopusa.com/search.html?q=Spring+Rubbers
Universal Spring Spacers:
http://www.energysuspensionparts.com/Energy-Suspension-Coil-Spring-Isolators.asp
Spring rubbers:
THIS looks like it would do the job and fairly inexpensively as well! I'm going to do some reading on the topic and see what I need. Thank you! I didn't even know these were out there!
  • 3 weeks later...
I just dealt with the same issues of tire rub on my 1970 240z this week but mine was with OEM springs. I can tell you that coil overs with stiffer springs total took care of this. I have 225/60/14 and have no rub now and I love the ride! I also switched to Bilstein B8 Sport all around, spring rate at 300. Much better handling, no rub, and adjustable ride height. Highly recommended.
Steve
  • Who's Online   2 Members, 1 Anonymous, 740 Guests (See full list)
