well, if you change your mind and go for poly... read the following links first... you will save time when you want to lube them when they start to squeak ;)
http://rallyways.com/specialty/part-2-powerflex-poly-bushings-miata-installation/
http://www.924board.org/viewtopic.php?t=20836
