March 29, 201510 yr comment_466678 Zcarsource.com has Tokico Blues........that's what I would go with! Link to comment https://www.classiczcars.com/forums/topic/51194-suspension-redo/?&page=2#findComment-466678 Share on other sites More sharing options...
March 29, 201510 yr Author comment_466732 They are on the way Guy. Â Looks like the front end will be next on my list of to do. Â I cannot wait to see their state. Maybe I will install the bump steer spacers when I do this job. I have been meaning to give those a try. Link to comment https://www.classiczcars.com/forums/topic/51194-suspension-redo/?&page=2#findComment-466732 Share on other sites More sharing options...
April 3, 201510 yr Author comment_466989 Who hoo! all of my parts came in !  time to get to work! The Eibachs are MUCH longer springs than the tokicos!  I think I am going to be happy. Pics to follow of course. Link to comment https://www.classiczcars.com/forums/topic/51194-suspension-redo/?&page=2#findComment-466989 Share on other sites More sharing options...
April 3, 201510 yr comment_467000 Yeah Zedy, they are longer, but don't be surprised when they compress to a much smaller length. I found mine actually seemed to have the upper coils touching each other. As you may notice from my sig. I went back to the original springs. Two reasons: 1) I got tired of scraping things like speed bumps, and 2) the ride, while a bit softer than tokicos was still too harsh for my old butt. The car still drives great, though. Good luck with your spring exchange. Cheers, Mike Link to comment https://www.classiczcars.com/forums/topic/51194-suspension-redo/?&page=2#findComment-467000 Share on other sites More sharing options...
April 3, 201510 yr Author comment_467004 New shocks are WORLDS stiffer. I am not sure I can even press them down  Such a difference damping these will provide. I cannot wait to see who they feel.  I will provide pics of my springs. the difference is staggering.  And since I have NEVER seen a direct tokico / eibach spring comparison.. here she is!   My biggest issue is determining which is front and which is back. I am going to run the part numbers just to be sure.  UPDATE: After some research it seems that the fronts are the parts ending in the 1  Therefore the front springs are the longer ones:  6305.001 Then the shorter springs are the rear ones: 6305.202  What everything I have found, this should be the ticket.   Guy can you confirm? Edited April 3, 201510 yr by Zedyone_kenobi Link to comment https://www.classiczcars.com/forums/topic/51194-suspension-redo/?&page=2#findComment-467004 Share on other sites More sharing options...
April 3, 201510 yr comment_467007 I have the Eibach's with illumina's and like them.If the 240 springs are similar to the 280, remember that the 001's go on the front. Link to comment https://www.classiczcars.com/forums/topic/51194-suspension-redo/?&page=2#findComment-467007 Share on other sites More sharing options...
April 3, 201510 yr comment_467008 Yes....I'm almost sure that would be correct ......the longer springs (1) would go in the front to offset the engine weight. The rear springs would end in the number (2). Link to comment https://www.classiczcars.com/forums/topic/51194-suspension-redo/?&page=2#findComment-467008 Share on other sites More sharing options...
April 3, 201510 yr comment_467032 you are wise to sort out the front/rear placement before the install, as you would wind up with a very odd stance - been there... Link to comment https://www.classiczcars.com/forums/topic/51194-suspension-redo/?&page=2#findComment-467032 Share on other sites More sharing options...
April 4, 201510 yr comment_467035 New shocks are WORLDS stiffer. I am not sure I can even press them down  Such a difference damping these will provide. I cannot wait to see who they feel. At the risk of being pedantic... Just because you can't press the shock down by hand doesn't really mean it'll be stiffer in application. Most of what you're doing by pressing it down on the bench is fighting the internal gas charge. You might not even be collapsing it quickly enough to get a real sense of the hydraulic valve damping. It's not the gas charge that does the damping, it's the oil. I'm no suspension guy, but it sounds like you're equating a high amount of gas pressure with a high amount of damping function, and I don't think you can legally do that. Link to comment https://www.classiczcars.com/forums/topic/51194-suspension-redo/?&page=2#findComment-467035 Share on other sites More sharing options...
April 4, 201510 yr comment_467050 i usually equate a high amount of gas pressure with a high amount of legume consumption, and i don't know why you can legally do that... Link to comment https://www.classiczcars.com/forums/topic/51194-suspension-redo/?&page=2#findComment-467050 Share on other sites More sharing options...
April 4, 201510 yr comment_467051 I have been dealing with a ride height issue for some time now and I just installed the I just installed Eibach's springs Tokicos HP Blues last weekend (well I had someone else install them). More to come on this later... My 240Z is a complete is a complete nut and bolt restoration.  All stock no mods.  The entire suspension is brand new, and I mean everything. But when the suspension was assembled the first time I had them put the original springs back in hoping to maintain the stock ride height.  The first struts I installed at the time were KYB's.  After everything settled I found that the rear was sagging and also lifting the front of the car up at the same time.  I figured I made a mistake by putting in the tired 45 year old springs. Fast forward to last week.  I had my springs and struts replaced with the Eibach and Tokicos.  First I must say that the ride is so much better than my original springs and KYB's.  It's like night and day.  Soft for every day driving but quickly tighten up when you give it throttle or dive in to a corner.  My problem now is the car still sags in the rear.  It's better than it was but still noticeable.  I don't know what to do now because everything that can be replaced has been replaced.  My only thought is that maybe the upper strut spacers were never installed originally because the original rubber spacers were bonded to the inside of the upper insulators) (FYI fronts have bearings instead of spacers).  I know I purchased poly replacement spacers from MSA but there's a possibility they were never installed.  The only way to find out is to drop the suspension again and remove the insulator from the spring assembly. â€‹So that's where I'm at.  I was going to take pictures tomorrow of how she sits.  If I stop hard when I park it levels out a little more but I don't want to keep doing that.  It's embarrassing. If the spacers are in fact in there I may just swap the rear insulators out for the 280Z version which are 3/4"-1" taller. â€‹Sorry for the lengthy post.  I'm interested to see how everything works out for you.  And yes, 1's in front and 2's in the rear and they should be installed with the text on the spring facing up like normal.  For the HP struts it's the same thing except 3's and 5's I think.  Smaller number goes in front. Matt Link to comment https://www.classiczcars.com/forums/topic/51194-suspension-redo/?&page=2#findComment-467051 Share on other sites More sharing options...
April 4, 201510 yr comment_467060 When they rebuilt your suspension, did they torque the bushings loaded or unloaded? If they didn't torque it loaded that can affect the stance...C Link to comment https://www.classiczcars.com/forums/topic/51194-suspension-redo/?&page=2#findComment-467060 Share on other sites More sharing options...
