April 17, 20159 yr comment_467921 He could have the "sticky pedal" issue my red 240 has. I haven't fixed it yet so I can't offer any advice other than what I've read about a cable being used instead of the rod. EDIT: "Sticky Throttle Linkage" Edited April 17, 20159 yr by siteunseen Link to comment https://www.classiczcars.com/forums/topic/51226-back-and-forth-shaking-started-while-accelerating-in-1st-gear/?&page=3#findComment-467921 Share on other sites More sharing options...
April 19, 20159 yr Author comment_468083 He could have the "sticky pedal" issue my red 240 has. I haven't fixed it yet so I can't offer any advice other than what I've read about a cable being used instead of the rod. EDIT: "Sticky Throttle Linkage" Problem was solved! Valves were badly adjusted! Ones even were adjusted to .014. The mechanic also found out the coil is getting very hot and the spark coming out to the spark plugs is very weak! I have a 3.0 Ohms flamethrower coil connected through a ballast resistor. The car does start up immediately. Could the Ballast Resistor or the coil be possibly damaged? If i decide to replace it should i go for a 1.5 ohm flamethrower Coil or is it better an MSD? Link to comment https://www.classiczcars.com/forums/topic/51226-back-and-forth-shaking-started-while-accelerating-in-1st-gear/?&page=3#findComment-468083 Share on other sites More sharing options...
April 20, 20159 yr comment_468087 Why do you have a ballast resistor with a 3.0 ohm coil? Who did that? I don't know much electrical but while searching the electrical forum today, for a different topic, I read posts on a number of threads saying you're not supposed to do that. You might want to wait for a person with more ignition knowledge to back this up, but maybe you should try running it without that resistor. Link to comment https://www.classiczcars.com/forums/topic/51226-back-and-forth-shaking-started-while-accelerating-in-1st-gear/?&page=3#findComment-468087 Share on other sites More sharing options...
April 20, 20159 yr Author comment_468094 Yes i need to clear this out!! I dont know why the former owner had installed it this way! The car does crank up fast! the problem is the idle! It has a rough idle which gets worse at traffic jams. Link to comment https://www.classiczcars.com/forums/topic/51226-back-and-forth-shaking-started-while-accelerating-in-1st-gear/?&page=3#findComment-468094 Share on other sites More sharing options...
April 29, 20159 yr Author comment_468861 The back and forth hesitation problem was over. I also needed to set both idle mixture knobs to 3.5 turns clockwise. If i set them leaner at 3 turns, the car did not showed enough power in 1st and second gear. The rpms are set at 950 to 1000 and i bypassed the ballast resistor. I have not opened the gap of the spark plugs. I have them set at.028 as they came from Factory (NGK BP6ES). Link to comment https://www.classiczcars.com/forums/topic/51226-back-and-forth-shaking-started-while-accelerating-in-1st-gear/?&page=3#findComment-468861 Share on other sites More sharing options...
