April 13, 20159 yr comment_467585 Yeah, i'll try both ways. Thanks. I am too graced with shovel-like hands. They used to call me Jeti back in elementary school....hah.. Link to comment https://www.classiczcars.com/forums/topic/51239-speedo-removal/?&page=3#findComment-467585 Share on other sites More sharing options...
April 13, 20159 yr comment_467586 If the 23 mm doesn't work. Find a ~10 mm and cut a notch in it with a grinder so it'll sit over the wing. I find it works well. Link to comment https://www.classiczcars.com/forums/topic/51239-speedo-removal/?&page=3#findComment-467586 Share on other sites More sharing options...
April 13, 20159 yr comment_467610 The 280Z's don't use the wingnut. Â There's one screw in the top of the ring in front of the lens, and one in the mounting bracket, dead center behind and underneath. Â Plus, at least on my 76, there is a bunch of clutter around the back of the gauges. Â Not much room at all. Â Good suggestion, but wrong car. Link to comment https://www.classiczcars.com/forums/topic/51239-speedo-removal/?&page=3#findComment-467610 Share on other sites More sharing options...
April 20, 20159 yr comment_468100 Wingnuts in my Z were about 19mm. Taking out the tachometer was a bitch, but taking out the speedo was even bitchier. The upper wingnuts were accesible, but stuck as F. Tools that i found most usable were this "pipe" type socket and strong fingers. I bust all my knuckles, almost destroyed my thumb trying to press the wingnuts open, my hands look like i was in a fist fight but it is OUT. Â Â Link to comment https://www.classiczcars.com/forums/topic/51239-speedo-removal/?&page=3#findComment-468100 Share on other sites More sharing options...
April 21, 20159 yr comment_468203 Borrowing this thread one more time. Ive attached new speedo and replaced all the bulbs. For some reason only the blue light indicator works when i switch to long lights. Do i need to ground them somehow or what? I have no tach on place. Link to comment https://www.classiczcars.com/forums/topic/51239-speedo-removal/?&page=3#findComment-468203 Share on other sites More sharing options...
April 22, 20159 yr comment_468298 To clear out the one above, lights that should illuminate speedo, wont work. Edited April 22, 20159 yr by Reverend Link to comment https://www.classiczcars.com/forums/topic/51239-speedo-removal/?&page=3#findComment-468298 Share on other sites More sharing options...
April 23, 20159 yr comment_468389 Ah, they ground on the holding brackets. No worries. Link to comment https://www.classiczcars.com/forums/topic/51239-speedo-removal/?&page=3#findComment-468389 Share on other sites More sharing options...
