So, first of all, i've been gone from the car circles for a long time for certain reasons. Have forgot most what i learned about carbs and timing.
Problem: last summer, i broke my distributor. Yes, it went broken. The collar that holds dizzy on place (with 2 10mm screws) was bent and eventually dizzy started to wiggle, so forth destroying all screw threads that were holding it to place. SO. I replaced it with similar kind of oem 240z distributor (no-points, custom made) and i just CANT make it run nicely.
I have 3 SK/OER dual sidedrafts that were tuned last summer. Havent touched them since. I dont remember the basics of timing, but i have timing gun with igniton advance setting.
Tell me what are the correct numbers for proper timing on 3 carbs. We tried every combo. It sometimes idled super smooth, then when rpms raised, ran like $^!#.
In two weeks we have major car event here, i just need it to be done with before the show.
Thanks in advance
https://www.classiczcars.com/forums/topic/51275-it-aint-running-right/
Carbs are set up and synced by the tuner last summer when i had the previous dizzy operational. I tried with 18 degrees initial. It idled okay but as soon as i raised rpms, its started to poppoppoppoppopp on the exhaust.
Edited by Reverend
Uhm and how does that look ? Petronix ? No points ?
Timing with vacuum unhooked, I would try something like 5 BTDC, hook up the vacuum and blip the throttle, should go no further than max 15 to 17 BTDC on the timing mark on the pulley ( use timing light ).
I have no vacuum advance as im running triples. The dizzy is modified by one old geezer who does these things. Its basic 240z dizzy, no-points with a small box outside. Nothing fancy. And yeah, i can smell fuel. Actually even my neighbour from 100 feet away can smell the fuel... haha. Wich is weird cause the dyno guy said its "okay". Is it normal that my whole rear area goes super BLACK after driving for some time? It looks like im driving a diesel... haha.
Edited by Reverend
Your problem seems to be too much fuel.
4 & 5 seem less rich.
Do you or a friend have an air-fuel measuring device?
Quick and dirty first step would be to lower fuel level if you do not have leaner jets.
You could also get hotter plugs (5) rather than (6) heat rating.
post-6852-0-15161400-1428714708_thumb.jp
