So, first of all, i've been gone from the car circles for a long time for certain reasons. Have forgot most what i learned about carbs and timing.
Problem: last summer, i broke my distributor. Yes, it went broken. The collar that holds dizzy on place (with 2 10mm screws) was bent and eventually dizzy started to wiggle, so forth destroying all screw threads that were holding it to place. SO. I replaced it with similar kind of oem 240z distributor (no-points, custom made) and i just CANT make it run nicely.
I have 3 SK/OER dual sidedrafts that were tuned last summer. Havent touched them since. I dont remember the basics of timing, but i have timing gun with igniton advance setting.
Tell me what are the correct numbers for proper timing on 3 carbs. We tried every combo. It sometimes idled super smooth, then when rpms raised, ran like $^!#.
In two weeks we have major car event here, i just need it to be done with before the show.
Thanks in advance
https://www.classiczcars.com/forums/topic/51275-it-aint-running-right/
If I have read all the posts in this thread correctly. The car ran properly and had been tuned last summer. Dizzy broke and got replaced and problem showed up. If that is the case, then start at the dizzy and don't move on until you are 100% sure that timing, advance and spark are totally correct.
Charles
Yes. I'd do that but my brand new timing light wont work >:I Well i gotta get refund and get another one. And yes, i agree its gettin too much fuel. Those sparkplug holes were soaking wet.. Should i lean out the idle jets or try to tinker with floats? I do not have any float gauge or whatsoever.
Edited by Reverend
You can dial back the idle enrichment screws to get a good a/f at idle and have clean plugs when idling.
But if the fuel level is too high or the jets are too big then once off idle, the car will still be rich.
Try a few plug cuts at different loads to see what plugs (a/f) is off idle:
1. Cruising
2. Accelerating up a long hill at WOT.
As the guys mentioned above, if your distributor is not advancing, the fuel will burn later as it is leaving the exhaust. I don't think this will blacken the plugs though... but your exhaust will be very hot and may glow at night.
I managed to get my timing gun back on track and set up the initial to 15 and max is about 37-38. Something is wrong. It does not run on all six cylinders on idle. Is it normal that you get fuel dripping from the ram pipes/float breathe hole?
Edit. I made few test drives and it stutters on steady speed. Plugs are black-ish so its most certain it is getting too much fuel. Was there DYI fuel level gauge instructions somewhere here?
Edited by Reverend
Your timing seems ok.
For SK's there is a screw for lowering the fuel.
There is a gauge like an eye dropper you can experiment with.
A pipette may do the trick.
You could probably dip a stick or the end of a caliper to measure fuel depth.
The carbs should not leak.
fuel level adjuster
How to measure fuel level with oer tool (a pipette may work the same if you bottom it the same in all carbs.
http://www.classiczcars.com/topic/47089-sk-racing-carbs/?p=432407
how to measure with caliper (ignore the 25mm bs from Keith Franke that I stupidly parroted):
So basically all you need for fuel level measurement is a small plastic pipe, slim enough to fit in to main jet hole, put it in and close the other end. It "should" hold the fuel inside..right? Like pipet. OER fuel level was 29mm right?
Edited by Reverend
I think the oer gauge registers from the ledge where the main jet assembly screws in. For a tube/straw alternate method, you may wish to put a mark or ring on the straw so that it registers from the ledge......or just bottom it out and ensure all three are the same level.
The fuel level from the ledge should be 31mm to 27mm down. It is something you can adjust to tune. Just make sure all 3 carbs have the same level. Repeat the measurement a few times so that the straw measurement is accurate enough for your liking. Take pics to make a tach tip for all when you nail it.
Edited by Blue
Recently Browsing 0
