Bpaccaud Posted March 15, 2003 Share #1 Posted March 15, 2003 Can you tell me if it 's a critical area (Dangerous for the structure) can it'll be easyly repeared? Link to comment Share on other sites More sharing options...
Graeme Suckling Posted March 15, 2003 Share #2 Posted March 15, 2003 In my opinion, it is a critical area because it is part of the body that takes suspension stresses. There are 2 panels that gradually curve together to be spot welded at the bottom of the spring tower. I had to cut out the inner damaged panel (in the engine bay) and weld in a replacement. After all is repaired it is essential that all seams are cleaned, treated with Metal Prep (phosphoric acid), primed with etch primer, THEN sealed with a good quality seam sealer. It is the wheel arch seams that MUST be absolutely water tight. Follow with primer and top coat.:classic: A big mistake that the factory made (makes?) is sealing these types of seams BEFORE treating the metal. Then, as you could imagine, it is only a matter of time before the corrosion works its way out. :tapemouth Link to comment Share on other sites More sharing options...
Bpaccaud Posted March 15, 2003 Author Share #3 Posted March 15, 2003 thanks for your reply!The car i purchase have the rust in the middle of the spring tower, just behind the middle of the spring, my idea was to cut the rust area (10cm/5cm) and patch with a good metal job, and treat befor and after weld, with a phosphasting rust removal, and after, treat with phosphating primer.What did you think about my idea Link to comment Share on other sites More sharing options...
Graeme Suckling Posted March 15, 2003 Share #4 Posted March 15, 2003 Sounds good to me. I am a staunch advocate of replacing rotted metal with new metal. NO FILLER TO MAKE IT LOOK GOOD. Filler is only for a difference in levels or deep scratches etc. Also there is the problem of structural components and in a unibody, IT IS ALL STRUCTURAL! Link to comment Share on other sites More sharing options...
