July 16, 20168 yr Author comment_498869 Can't upload pics. Tried a work around but it posted an empty reply... Edited July 16, 20168 yr by Patcon Link to comment https://www.classiczcars.com/forums/topic/51280-caswell-plating/?&page=7#findComment-498869 Share on other sites More sharing options...
July 16, 20168 yr Author comment_498889 This is some of the hardware I plated last week These large bushings and washers came out really good too... Â This hinge plate is a little dark but isn't burnt on the top edge like the picture makes it appear This bar came out really good. Obviously some of these parts are not Z parts. They are off the skid steer I'm working on... Link to comment https://www.classiczcars.com/forums/topic/51280-caswell-plating/?&page=7#findComment-498889 Share on other sites More sharing options...
July 16, 20168 yr Author comment_498892 @Namerow this is todays effort, more skid steer bolts started with some bolts with surface rust bead blasted Lightly buff them against a wire brush on the grinder. If you use too much pressure it gouges and scratches the part up. If the pressure is light it makes them shiny. Into the crock pot with SP degreaser. RINSE Then I dip them in Muriatic acid for a pickle dip for 20-30 seconds. They pretty much quit fizzing when I pull them out. RINSE After plating 30 minutes at the calculated .15 amps/in This is a second batch plated for 30 minutes. I ran these a little higher to try to burn them a little bit RINSE  I bought some blue chromate a few weeks ago. This is what it does. I intentionally dipped them only part way to illustrate the affect  This is a 60 second dip in blue chromate Then I let them hang until dry Edited July 16, 20168 yr by Patcon Link to comment https://www.classiczcars.com/forums/topic/51280-caswell-plating/?&page=7#findComment-498892 Share on other sites More sharing options...
July 16, 20168 yr Author comment_498894 This is after the yellow chromate I dipped the bolts for 25 seconds and the washers for 20 seconds Then I lightly rinse with a spray bottle. If you get too aggressive you can rinse the chromate off. Shake the excess off. If it puddles and beads it will make dark spots. For things that really matter I dry them with light compressed air to keep them even... Edited July 16, 20168 yr by Patcon Link to comment https://www.classiczcars.com/forums/topic/51280-caswell-plating/?&page=7#findComment-498894 Share on other sites More sharing options...
July 16, 20168 yr comment_498915 Looks like you found your stride, I'd be happy with those results. Link to comment https://www.classiczcars.com/forums/topic/51280-caswell-plating/?&page=7#findComment-498915 Share on other sites More sharing options...
July 17, 20168 yr Author comment_498929 Thanks Chris, I am really close to having results as good as the shipment I already had professionally plated. If it doesn't improve from here I will still be happy... For posterity there are little things that can trip you up: The metal needs to be degreased before bead blasting or wire wheel work or you just spread the grease around The shinier the piece is before plating the better it will look when plated If the metal is pitted it's going to be pitted after plating There are ways around this but I haven't gotten to that level yet You need to calculate your areas accurately and use a timer to get consistent results I know there are some DIY methods for solutions but I didn't feel like trying to reinvent the wheel (that sounds a little insulting but is not meant to be I just have too many irons in the fire already and wanted the path of least resistance). The Caswell chemicals can get expensive, especially if you are dipping larger parts but over all I will break even or probably come out ahead considering I have several cars that need this kind of attention. I prefer plating myself because I can do things in really small batches and not have to loose fasteners or pull together a large order then sort them after plating... I noticed something today... I think it was Motorman7 who commented at some point that the yellow chromate finish is fragile when it is new. I found this to be the case today. After an hour or so I was messing with the bolts I plated. I could scratch the yellow off down to the blue chromate with my finger nail. I will let them harden for a few days and see if this persists. I have been letting the blue chromate dry before the yellow because I didn't want to contaminate the yellow chromate. I may have to dip wet to wet for the yellow to adhere properly... Â Â Edited July 24, 20168 yr by Patcon Link to comment https://www.classiczcars.com/forums/topic/51280-caswell-plating/?&page=7#findComment-498929 Share on other sites More sharing options...
July 24, 20168 yr Author comment_499400 @motorman7 I went back 24 hrs. later and 7 days later and both times I can still scratch the yellow chromate off with my finger nail. Rich, How fragile is you completed finish? I am thinking I need to yellow chromate immediately after blue. Do you have any issues with contaminating your yellow chromate with the blue chromate? Link to comment https://www.classiczcars.com/forums/topic/51280-caswell-plating/?&page=7#findComment-499400 Share on other sites More sharing options...
July 24, 20168 yr comment_499402 I do the yellow chromate immediately after the blue chromate, so the part is still wet. Â When the yellow chromate is done I dip the part in hot tap water then blow dry on high heat with a hair dryer. Â This works well for me and often I will install the bolts within an hour or two. Â I think the heat from the hair dryer is important in hardening the chromate. Â I typically dry the part for about a minute on high heat. Link to comment https://www.classiczcars.com/forums/topic/51280-caswell-plating/?&page=7#findComment-499402 Share on other sites More sharing options...
July 24, 20168 yr comment_499410 I know almost nothing about this whole process and I find it neat that you guys are able to do this kind of work. Is the chromate coating an electroplate process like the zinc, or is it just a paint like coating that "dries"? In other words, when you're applying the chromate, do you run electrical current through the parts, or do you just dip them into a solution and then pull them out? Link to comment https://www.classiczcars.com/forums/topic/51280-caswell-plating/?&page=7#findComment-499410 Share on other sites More sharing options...
July 24, 20168 yr Author comment_499411 The plating tank, where the zinc coating is applied, is the only tank that uses current. The chromate tanks are just a dipping solution but I believe they have an acid base to make the process work... Link to comment https://www.classiczcars.com/forums/topic/51280-caswell-plating/?&page=7#findComment-499411 Share on other sites More sharing options...
July 24, 20168 yr comment_499453 Some people have baked their newly plated parts in an oven to harden the coating. You mentioned hydrogen embritlement in the first post on this thread but nobody answered your question. Â Perhaps this may help? finishing dot com website Edited July 25, 20168 yr by hr369 Link to comment https://www.classiczcars.com/forums/topic/51280-caswell-plating/?&page=7#findComment-499453 Share on other sites More sharing options...
July 25, 20168 yr Author comment_499458 I wonder if our application is really that susceptible to hydrogen embrittlement? It looks like 4 hrs @ 375dF for post plating hydrogen removal Link to comment https://www.classiczcars.com/forums/topic/51280-caswell-plating/?&page=7#findComment-499458 Share on other sites More sharing options...
