Thank you guys, that's what I'll do for now.
If you do run rubber lines under the battery you should make some sort of shield to prevent acid from getting on the lines.
A piece of roof flashing would work. Make a longways bend in it to give it some strength.
I had thought of running the hose through 1/2" section of PEX. Acid won't hurt plastic I'm guessing as it comes in plastic containers.
EDITED FOR DYSLEXIC MIND
a section of 1/2" PEX
Edited by siteunseen
