Some FSM and Carparts Distributor Data
240260280z
Weight
71 22109-71300
72 22109-A5500
74 22109-A5500
75 22109-A5500
Spring
71 22110-E4600
72 22110-E4602
73 22100-N3300
74 22100-N3600
75 22110-N4200
Cam
71 22132-E4600
72 22132-E4600
74 22132-N3600
75 22132-N4200
76 22132-N4300
Condensor
71 22102-00801
70-71 FSM D606-52 (manual)
Total: 34.5
Init  17
Mech   6 @ 1000
Vac   5.5
72 FSM D606-52 (manual)
Total: 34.5
Init  17
Mech   6 @ 1000
Vac   5.5
73 FSM D611-54 (manual)
Total: 35
Init 7
Mech 11 @ 1400
Vac  6
74 FSM D6F3-01 (manual)
Total: 39
Init 7
Mech 13 @ 1600
Vac  6
75 FSM D6F4-01 (manual)
Total: 34.5
Init 7
Mech 10 @ 1360
Vac  7.5
(6 electrical)
76 FSM D4F4-01 (manual)
Total: 34.5
Init 7
Mech 10 @ 1360
Vac  7.5
(6 electrical)
77 FSM D6F5-02(D6F6-06 Canada) (manual)
Total: 36
Init 10
Mech 8.5 @ 1250
Vac  9
78 FSM D6F5-02(D6F6-06 Canada) (manual)
Total: 36
Init 10
Mech 8.5 @ 1250
Vac  9
82 FSM D6K81-01 (manual)
Total: 40
Init 8
Mech 8.5 @ 1400
Vac  15
I've found several 76 and 77 distributors with 11 stamped on the slotted portion (the cam, I assume it's called).  Not sure the FSM is 100% on what actually came in the cars.  Assuming the stamped numbers are the maximum centrifugal advance.
Has anyone ever determined what the typical CARDONE rebuild distributor has?  They show the same distributor as compatible with many years.  They must have chosen some middle ground.
I'm interested in the CARDONE questions as well....I've gotta think that a re-manufactured distributor has to be in better shape than my 42 year old one (and I actually have 2 original ones).  Getting some minor fluctuation on my vacuum gauge and it appears to be electrical related.
