Email logins are now active ×
L28+(maxima)47 build
  • 3 weeks later...
Actually moving forward again on the motor. The big cam arrived and I can start doing lash pads . Should get lucky and have just two sizes , and I have a set for the one size. Short block is just where I left it - all assembled under the bench. Things should roll pretty fast now. I was hoping for this high drama push to put the big motor in at the last minute to make it to Z con- but reality just kicked my arse again. Be glad to take the 2.4 !
Well my 190 lash pads arrived yesterday so I am chumping at the bit to get going on assembly,  trying to take a deep breath before start. Don’t want to rush this . Biggest thing to check now is piston to valve clearance . All other projects are put on hold until this thing is assembled !
Also think I snagged a G-force t-5 trans to mate up with this. For those not familiar it is the Nissan T-5 from the ZXT that gets its guts ripped out and replaced with WC T-5 guts. Larger main shaft and tougher gear sets . Pro- tower shifter , hydraulic TOB! The beauty is that you get a trans that is good for 600 hp , better gear ratios and it just bolts up!
  • Like 3
Lash pads installed !
.525 lift and still room for the valves and pistons to share. Waiting on a adjustable cam sprocket and still debating on the balancer . Thinking about spending the $$ because I want to use it on my L32 eventually . Also waiting on some hardware to finish buttoning up things .
Did you have to remove any material off the 190 lash pads?  If you did would you mind sharing your method?  Thank you Steve.
Why would I remove material? I figured the size I needed and ordered the correct ones
1 hour ago, siteunseen said:
I bought a cam kit that came with 190s.  It's a .460 lift.  Thank you for your reply.
So what size do you need? The lash pads are available . Have you done a wipe with stock pads?
  • Who's Online   0 Members, 0 Anonymous, 583 Guests (See full list)
