October 3, 20195 yr Author comment_585090 It’s magnetic . I’ve seen enough welding splatter to know that it will burn into anything. I’m usually going a mile a minute in the shop , so I must have gotten careless . Ive built a rotisserie and numerous other things while I’ve had this head . I was waiting on a cam before I buttoned it up. Just bad luck. I at least salvaged the engine. Another lesson learned . Link to comment https://www.classiczcars.com/forums/topic/51459-l28maxima47-build/?&page=16#findComment-585090 Share on other sites More sharing options...
October 3, 20195 yr comment_585093 Carp. Well at least you caught it before it did something unrecoverable. You must have pretty good ears to have heard that issue so early! Clean room... That's what I need. Link to comment https://www.classiczcars.com/forums/topic/51459-l28maxima47-build/?&page=16#findComment-585093 Share on other sites More sharing options...
October 3, 20195 yr Author comment_585099 8 hours ago, Captain Obvious said: Carp. Well at least you caught it before it did something unrecoverable. You must have pretty good ears to have heard that issue so early! Clean room... That's what I need. What I heard what that #5 main I believe . It hadn’t spun yet but was ready. Or - what I heard was the piston hitting the head around the damaged areas. The holes left raised areas around them on both the piston and head. There simply wasn’t enough clearance and they were slightly tapping each other as the engine heated up and things expanded. Another lesson I was schooled on by my machinist. Don’t just throw new rods bolts in - ARP or otherwise without having rods re-sized a the big end. This was a budget build on the short block, but at 10$ per rod I got to cheap and that could have also caused premature wear. It was more ignorance than $$ , but don’t have that excuse anymore . Link to comment https://www.classiczcars.com/forums/topic/51459-l28maxima47-build/?&page=16#findComment-585099 Share on other sites More sharing options...
October 4, 20195 yr comment_585127 14 hours ago, madkaw said: What I heard what that #5 main I believe . It hadn’t spun yet but was ready. Or - what I heard was the piston hitting the head around the damaged areas. The holes left raised areas around them on both the piston and head. There simply wasn’t enough clearance and they were slightly tapping each other as the engine heated up and things expanded. Another lesson I was schooled on by my machinist. Don’t just throw new rods bolts in - ARP or otherwise without having rods re-sized a the big end. This was a budget build on the short block, but at 10$ per rod I got to cheap and that could have also caused premature wear. It was more ignorance than $$ , but don’t have that excuse anymore . So your machinist is reiterating what the rebuild book says about rod bolts affecting journal roundness or shape. Interesting... @Captain Obvious Did you mic a journal and then relocate the bolts yet? Link to comment https://www.classiczcars.com/forums/topic/51459-l28maxima47-build/?&page=16#findComment-585127 Share on other sites More sharing options...
October 4, 20195 yr Author comment_585128 Any change in the bolts could be a change in the pilot center and cause the shells to off ever so slightly. Maybe okay for DD , but I should have known better for a performance build. Link to comment https://www.classiczcars.com/forums/topic/51459-l28maxima47-build/?&page=16#findComment-585128 Share on other sites More sharing options...
October 4, 20195 yr comment_585129 No, I haven't taken any measurements off mine. I know I popped two of them out enough that they could have spun 180 degrees. I don't know for sure if they really did spin or not. And the two that popped out far enough that they could have spun were not on the same piston. So I know with certainty that both bolts are in their original positions on four pistons and at least one of the two bolts are correct on the other two pistons. That's all I got right now. I ain't skeeered. Haha!! Link to comment https://www.classiczcars.com/forums/topic/51459-l28maxima47-build/?&page=16#findComment-585129 Share on other sites More sharing options...
October 4, 20195 yr Author comment_585132 I think most build you can get away with just throwing in bolts , it just wasn’t my day . And there’s no true evidence that the bolts did anything to the motor, could have been a chunk of something that ate the bearing What’s weird is my machinist kind of gave me a nick name of ‘lucky’. Can’t tell if he was being facetious or he was saying I’m lucky to have so little damage . One of the machinists there was admiring the L’s many main journals . “ they really got that crank locked down”, is what he said . Edited October 4, 20195 yr by madkaw Link to comment https://www.classiczcars.com/forums/topic/51459-l28maxima47-build/?&page=16#findComment-585132 Share on other sites More sharing options...
October 4, 20195 yr comment_585144 42 minutes ago, madkaw said: What’s weird is my machinist kind of gave me a nick name of ‘lucky’. Can’t tell if he was being facetious or he was saying I’m lucky to have so little damage . Haha! Yeah, that could go either way! And you might not want to know which way. I wonder if you had welding beads flying all around enough that you got one stuck to a valve guide... Who knows where else they landed?? Link to comment https://www.classiczcars.com/forums/topic/51459-l28maxima47-build/?&page=16#findComment-585144 Share on other sites More sharing options...
October 8, 20195 yr Author comment_585372 Well to make feel even better today my machinist told me that the rods definitely should be resized . After torque was set and measuring they were off slightly . I won’t make that mistake again - lol Link to comment https://www.classiczcars.com/forums/topic/51459-l28maxima47-build/?&page=16#findComment-585372 Share on other sites More sharing options...
October 9, 20195 yr comment_585392 You sure are "lucky"! Hope that's the last issue!! Link to comment https://www.classiczcars.com/forums/topic/51459-l28maxima47-build/?&page=16#findComment-585392 Share on other sites More sharing options...
October 10, 20195 yr Author comment_585433 11 hours ago, Captain Obvious said: You sure are "lucky"! Hope that's the last issue!! Oh no - I can’t be that lucky . Machinist finished up the parts and when I got home I realized he scratched the head surface with his valve seat tool. I drove home 25 miles to realize he didn’t give me the actual valve he touched up- left it in the table. Then I stared at the valve seat and realized he ground it wrong . Plus I see a huge scratch on the head surface . I’m not even mad though- it was one of those days . My truck started to run bad in the way home - dying every time I stopped . Can’t be mad at my machinist either . He’s 72 and nearly died a month ago from a broken stent in his leg. He’s hands shake pretty badly , but he presses on . He was finishing up the head as I waited and I think I rushed him . He feels bad and wanted me to bring it back this evening . Looks like I might have to adjust my CR calculation . It will take at least 15 thou to clean this up . Maybe it will take most of the dents out too -lol. Edited October 10, 20195 yr by madkaw Link to comment https://www.classiczcars.com/forums/topic/51459-l28maxima47-build/?&page=16#findComment-585433 Share on other sites More sharing options...
October 10, 20195 yr comment_585452 Oh no! I guess when it rains, huh? I'm sorry to hear about the multiple calamities. I don't know how to estimate what the change will be to chamber volume with a .015 shave. Are you going to measure the volume, or just guess a reduction amount? Link to comment https://www.classiczcars.com/forums/topic/51459-l28maxima47-build/?&page=16#findComment-585452 Share on other sites More sharing options...
