December 20, 20195 yr Author comment_589632 #6 - where I had most if the issues . There was also a spot on #5 . Link to comment https://www.classiczcars.com/forums/topic/51459-l28maxima47-build/?&page=20#findComment-589632 Share on other sites More sharing options...
December 20, 20195 yr comment_589640 Woof. Still considering yourself "lucky"? So you're thinking oil getting pulled up past the rings and then getting sucked out the intake valves into the plenum? Link to comment https://www.classiczcars.com/forums/topic/51459-l28maxima47-build/?&page=20#findComment-589640 Share on other sites More sharing options...
December 20, 20195 yr comment_589649 Hard to do a leak down test at BDC except when the cam is out. Perhaps fill chamber with oil or diesel and use a dipstick through plug hole to measure drop over a day. Link to comment https://www.classiczcars.com/forums/topic/51459-l28maxima47-build/?&page=20#findComment-589649 Share on other sites More sharing options...
December 20, 20195 yr Author comment_589652 On 12/20/2019 at 2:54 AM, Captain Obvious said: Woof. Still considering yourself "lucky"? So you're thinking oil getting pulled up past the rings and then getting sucked out the intake valves into the plenum? Yes - still lucky to be fortunate enough to play like this . And yes oil was getting by the rings somehow. My machinist is an old racer and has seen everything . He actually went thru the same thing . A ring defect was allowing oil to contaminate the combustion mixture . THe fact I’m pushing 225 psi amplifies the condition I believe . Im going to get some larger pistons and salvage the engine - AFTER I finish and get the 3.2 running . Link to comment https://www.classiczcars.com/forums/topic/51459-l28maxima47-build/?&page=20#findComment-589652 Share on other sites More sharing options...
December 20, 20195 yr comment_589653 Damn! That bites, I know the feeling well, sometimes you just miss stuff. But you're right, we are all lucky enough to be able to play like this. Thanks for showing us warts and all, you don't learn much from perfection. Link to comment https://www.classiczcars.com/forums/topic/51459-l28maxima47-build/?&page=20#findComment-589653 Share on other sites More sharing options...
December 20, 20195 yr Author comment_589655 On 12/20/2019 at 12:30 PM, grannyknot said: Damn! That bites, I know the feeling well, sometimes you just miss stuff. But you're right, we are all lucky enough to be able to play like this. Thanks for showing us warts and all, you don't learn much from perfection. Don’t mind sharing my mistakes . I’ve learned reading about others too. It would be easy to blame my cheapy Ebay Perfect Circle old stock rings that gapped bigger than stock, but that’s not the real reason. Can’t expect rings to seal on a sketchy bore. In the end, I’m glad to know why this stuff was happening and not blame it on cheap parts Link to comment https://www.classiczcars.com/forums/topic/51459-l28maxima47-build/?&page=20#findComment-589655 Share on other sites More sharing options...
December 20, 20195 yr Author comment_589656 On 12/20/2019 at 12:30 PM, grannyknot said: Damn! That bites, I know the feeling well, sometimes you just miss stuff. But you're right, we are all lucky enough to be able to play like this. Thanks for showing us warts and all, you don't learn much from perfection. Don’t mind sharing my mistakes . I’ve learned reading about others too. It would be easy to blame my cheapy Ebay Perfect Circle old stock rings that gapped bigger than stock, but that’s not the real reason. Can’t expect rings to seal on a sketchy bore. In the end, I’m glad to know why this stuff was happening and not blame it on cheap parts Link to comment https://www.classiczcars.com/forums/topic/51459-l28maxima47-build/?&page=20#findComment-589656 Share on other sites More sharing options...
December 20, 20195 yr comment_589657 Yeah, thanks for sharing all this stuff. Knowledge is certainly a type of wealth. Edited December 20, 20195 yr by Reptoid Overlords Link to comment https://www.classiczcars.com/forums/topic/51459-l28maxima47-build/?&page=20#findComment-589657 Share on other sites More sharing options...
December 20, 20195 yr comment_589660 I agree. No sense hiding our failures. If everyone thinks we never make mistakes, who are we kidding! I’ve never learned anything doing it perfect the first time; mistakes make us better at what we do........ and I’m getting “better “ all the time... Link to comment https://www.classiczcars.com/forums/topic/51459-l28maxima47-build/?&page=20#findComment-589660 Share on other sites More sharing options...
December 20, 20195 yr comment_589691 On 12/20/2019 at 3:08 PM, wheee! said: I agree. No sense hiding our failures. If everyone thinks we never make mistakes, who are we kidding! I’ve never learned anything doing it perfect the first time; mistakes make us better at what we do.... .... and I’m getting “better “ all the time... Confirmed by the gentleman who made WD1 - WD39 Link to comment https://www.classiczcars.com/forums/topic/51459-l28maxima47-build/?&page=20#findComment-589691 Share on other sites More sharing options...
December 21, 20195 yr comment_589711 And the guy who made preparations A through G. They were complete failures. Link to comment https://www.classiczcars.com/forums/topic/51459-l28maxima47-build/?&page=20#findComment-589711 Share on other sites More sharing options...
December 21, 20195 yr comment_589712 On 12/20/2019 at 11:38 AM, madkaw said: Yes - still lucky to be fortunate enough to play like this . I know, and I agree completely. I was just making a joke about the nickname your mechanic coined said some time ago. Link to comment https://www.classiczcars.com/forums/topic/51459-l28maxima47-build/?&page=20#findComment-589712 Share on other sites More sharing options...
