https://www.youtube.com/watch?v=pOd9WsNmz2Q
hi please watch the video and let me know your opinion
and how center dismantle and reassembly the JET ( if is correct name ) the parts under the carb that go down and no return in up in appropriate mode.
thanks
Disconnect the flat linkage attached to the jet nozzle & see if that allows the nozzle to slide up & down smoothly.The linkage occasionally needs a bit of a twist to align perfectly with the bushing & screw. Slide the nozzle up & down with & without the jet needle in place & do the drop test on the piston to ensure the nozzle is aligned with the jet. Lube tho outside of the jet nozzle before reassembly.
  • 2 years later...
I'm no expert but when it happened to a set I bought I disconnected the hose and twisted the nozzle until it would pull out. It just old gas/ varnish that has it stuck. Pull the hose and slowly turn it until it loosens up.
