SU carb JET problem how dismantle and reassembly ?
Disconnect the flat linkage attached to the jet nozzle & see if that allows the nozzle to slide up & down smoothly.The linkage occasionally needs a bit of a twist to align perfectly with the bushing & screw. Slide the nozzle up & down with & without the jet needle in place & do the drop test on the piston to ensure the nozzle is aligned with the jet. Lube tho outside of the jet nozzle before reassembly.
  • 2 years later...
