Posted March 16, 200322 yr comment_30032 Hi guys, I need a definite yes or no on this one..Is a 240Z Track Control Arm, also called a Transverse link, exactly the same as a 260Z's or a 280z's?Mine on the 240z looks to be damaged and I have a friend with a 280Z arm he can send me..Thanks.... Link to comment https://www.classiczcars.com/forums/topic/5149-suspension-gurus-help/ Share on other sites More sharing options...
March 16, 200322 yr comment_30035 The Tension Rod or T/C rod is the same for all cars up to 78. Link to comment https://www.classiczcars.com/forums/topic/5149-suspension-gurus-help/#findComment-30035 Share on other sites More sharing options...
March 16, 200322 yr Author comment_30038 Hi Keith,I wasn't referring to the Tension Rod I was referring to the Track Control Arm aka the Transverse Link.Thanks. Link to comment https://www.classiczcars.com/forums/topic/5149-suspension-gurus-help/#findComment-30038 Share on other sites More sharing options...
March 16, 200322 yr comment_30039 He means the actual Lower control arm, technically called the Traverse Link in the FSM.I don't know the answer for sure, but I BELIEVE that there are different P/N's for this part between 240Z and 280Z.Sorry I can't be of much help to you.Carl Link to comment https://www.classiczcars.com/forums/topic/5149-suspension-gurus-help/#findComment-30039 Share on other sites More sharing options...
March 16, 200322 yr comment_30040 After reading the reply from 2ManyZs, I'm not sure you guys are talking about the same part. The MSA catalog currently lists the "Lower Control Arm, Right 70-78" for $49.86. The equivalent part on the left size is listed as not currently available. The "Tension Rod, Left/Right 70-78" is available for $110.15. In either case, the answer to your question is "Yes". Link to comment https://www.classiczcars.com/forums/topic/5149-suspension-gurus-help/#findComment-30040 Share on other sites More sharing options...
March 16, 200322 yr comment_30045 Well George, you seem to have us confused what you mean by the transverse link.... The only part of the Z suspension that we'uns over on this side call the transverse link is in the rear suspension that connects the rear mounts of the control arms...If this is what you are referring to, they are interchangeable, although the 280 has a bend in it for more clearance for the R-200 rears our 280's had... Link to comment https://www.classiczcars.com/forums/topic/5149-suspension-gurus-help/#findComment-30045 Share on other sites More sharing options...
March 16, 200322 yr Author comment_30049 Hi all and thanks for the replys,The confusion arises, i think, due to the many various names for the same parts....Here are a couple of examples of front suspension terminology and what different sources call them. (I know they refer to the same item as the sources I have used include pictures of the parts in question)FSM: Transverse LinkHaynes Manual (UK): Track Control ArmVictoria British: Control Arm - LowerMSA: Control ArmFSM: Compression RodHaynes Manual (UK): Radius RodVictoria British: Tension RodMSA: Tension RodI have also heard this being called a T/C Rod.FSM: StabiliserHaynes Manual (UK): Cross MemberVictoria British: Front Cross MemberMSA: Cross MemberFSM: Suspension MemberHaynes Manual (UK): Stabiliser barVictoria British: Front Sway barMSA: Sway barThe FSM's interpretation of the last two components I have listed, what the FSM refers to as the Stabiliser and the Suspension Member, is so confusing I am wondering if this is a typo in the FSM. Link to comment https://www.classiczcars.com/forums/topic/5149-suspension-gurus-help/#findComment-30049 Share on other sites More sharing options...
March 16, 200322 yr Author comment_30052 The part I was referring to is located on the front suspension and depending which source you are using is called: FSM: Transverse Link Haynes Manual (UK): Track Control Arm Victoria British: Control Arm - Lower MSA: Control Arm THANKS Link to comment https://www.classiczcars.com/forums/topic/5149-suspension-gurus-help/#findComment-30052 Share on other sites More sharing options...
March 17, 200322 yr comment_30165 Yep, transverse link aka control arm, the Haynes calls the rear lower control arm a transverse link.I know this only because I had to remove the whole friggin thing to change the shoes in back, rotor was frozen solid to the center hub. Link to comment https://www.classiczcars.com/forums/topic/5149-suspension-gurus-help/#findComment-30165 Share on other sites More sharing options...
March 17, 200322 yr comment_30205 Originally posted by Mudge Yep, transverse link aka control arm, the Haynes calls the rear lower control arm a transverse link.I know this only because I had to remove the whole friggin thing to change the shoes in back, rotor was frozen solid to the center hub. The FSM also calls the Front lower control arm the traverse link. Link to comment https://www.classiczcars.com/forums/topic/5149-suspension-gurus-help/#findComment-30205 Share on other sites More sharing options...
